Home > Tdi > Gearbox Trouble???
Fatbaron
Gearbox Trouble???
I've just replaced both swivel joints and bearings on the 110 along with the drive members. Test drive went perfectly.
5 minutes from home a loud whirring noise started from underneath the seatbox, i wasn't sure if it was the prop or gearbox. Got home, put it in reverse, foot off the clutch and a bang. I thought it had jumped out so I re-engaged and tried again. This time, pretty horrific metal on metal noises, banging and juddering. Going forwards in first, not so bad but not a lot of drive.
This morning after an inspection I've noticed a UJ on the rear prop is destroyed.
The truck will move forwards in first with a bit of noise, in reverse its banging, juddering and actually siezed up.
I knocked it out of gear and still with my foot on the clutch it wouldn't push back. Knocked it in to first, then out and then it will push back.
Any ideas please folks?
I hope the above reads okay...
Post #852864 29th Aug 2020 9:15am
Mo Murphy
I think you've answered your own question, though by the sound of it the UJ has probably damaged the prop now.
HTH
50 Shades of Pennine Grey
Post #852894 29th Aug 2020 11:20am
landy andy
Put it in diff lock, remove rear prop. Does it drive?
Post #852897 29th Aug 2020 11:25am
Fatbaron
I'm changing the rear prop today so I'll see if it drives in diff lock without it. Luckily I've got another gearbox sat in the workshop.
I'm pretty sure it's the box, just wondered if anyone else has had the same problem.
Thanks for the replies. Thumbs Up
Post #853276 31st Aug 2020 7:27am
Dinnu
Do you know if you have the cross drilled input gear in the transfer box? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #853306 31st Aug 2020 9:21am
Fatbaron
Got the truck recovered back to the workshop, had a look inside the box and yeah... its the box! Shocked
I'd say catastrophic failure.?.
This is what fell out...
Post #854587 6th Sep 2020 5:51pm
Mdm
i have a spare tdi gearbox still in a rusty old disco that runs and can be test driven .
in case your not rebuilding that one or dont have a spare on the shelf
Post #854593 6th Sep 2020 6:48pm
90 Dreamer
If your lucky and have some superglue to hand then you can simply put them back on............ Whistle
Post #854602 6th Sep 2020 7:15pm
Wow, that's quite a failure!
Post #854616 6th Sep 2020 8:40pm
Dinnu
Was there any play on the bearings? especially the intermediate bearings take a punishment. Or the collapse tube not set correctly? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #854642 7th Sep 2020 4:42am
discomog
I think catastrophic failure is a good description. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #854644 7th Sep 2020 5:35am
Mo Murphy
Ouch ! That's a proper job !
Post #854657 7th Sep 2020 8:21am
L110CDL
Not seen one like that, that is bad Sad Clayton.
Keeper.
Post #854847 7th Sep 2020 9:21pm
Fatbaron
Cheers Mdm, luckily I have a spare, spent Sunday afternoon cleaning it up...
It had been left standing for a month on grass while I found some time to fit new swivel housings, bearings etc. so it either had a helluva oil leak that I didn't spot or just sh** happens!
I've decided to rebuild her onto a galv chassis since I've got this far. I'll be starting a build thread to cover it.
Post #854872 8th Sep 2020 6:46am
Fatbaron
Rolling with laughter
Post #854873 8th Sep 2020 6:47am
