Home > Puma (Tdci) > what connector is this for?
Peregrine_White
United Kingdom 2008 Defender 90 Puma 2.4 SW Keswick Green
I have a 2007 90 tdci and in the drivers side engine bay there is a loose connector with nothing plugged to it, the wire colours are (orange with blue) and a black wire. I have checked the wiring diagram to no avail. Any of you bright sparks able to point me in the right direction?
P.S My 90 is poverty spec
Post #852575 28th Aug 2020 10:41am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Check the clutch switch on the master cylinder...
Other than that I'm sure someone who's with the vehicle will be along with more useful advice soon Laughing Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #852587 28th Aug 2020 11:04am
PaulMc
It's for the alarm's bonnet switch. Paul.
Post #852590 28th Aug 2020 11:08am
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
alarm switch for sure
Post #852608 28th Aug 2020 11:57am
Peregrine_White
perfect thank you lads
Post #852650 28th Aug 2020 3:02pm
pme
you will find some more around the engin/gearbox, part of the ford loom, not used by LR. No HiLo light but there is a switch, (on my one at least)
Post #852651 28th Aug 2020 3:06pm
