Home > Maintenance & Modifications > scan tool recommendations OBD2
sikDefender
Australia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
hey.
noob here.
just started work on the rebuild of a very neglected puma 2.4 2010 - Stornaway grey.
I have many questions ( a lot of issues with this machine - but I have a couple of good mates that know them well)
I'm about to buy a scan tool the OBD2
https://obd2australia.com.au/product/land-...ll-system/
anyone familiar or used this handheld scanner ?
cheers if somethings hard to do, its not worth doing - Homer
*just jokes... try it till you break something
Post #850422 16th Aug 2020 11:55pm
Ianh
Not used that one.
The favoured one on here seems to be a nanocom, not cheap, but very good. I have one in addition to a basic obd2 elm327 Bluetooth unit that works with apps on my phone for everyday use.
If you have not spotted this thread it’s worth a read. https://www.defender2.net/forum/topic10829.html and perhaps message lorryman100 who will be able to advise on whether the one you highlighted is worth the money above a basic obd2 elm327 with phone app.
Post #850425 17th Aug 2020 12:41am
sikDefender
thanks Ian.
about your basic obd2 elm327 with app -
does that only do engine error codes or does it also give analysis of all other systems in defender?
this is what OBD2 AUS emailed me:
"If you get a full system scanner (you need to check first if it’s compatible with your vehicle) it will read and scan not only engine codes, but other systems as well like suspension, SRS, ABS, AIRCON etc. if somethings hard to do, its not worth doing - Homer
Post #850827 18th Aug 2020 11:13pm
