Home > For Sale & Wanted > [Sold] Defender 300 tdi/td5 Aircon
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Very rare complete Land Rover Defender 300tdi/TD5 Airconditioning Aircon. Condition is Used.
I got this to fit to my 300 TDI Defender but have now decided not to fit it as my plans for the vehicle have changed.
I believe it to all be there, but you can see from the pictures what is included. The only negative is some of the fins on the cooling matrix (radiator looking bit) Are crumbling .. so may need a new matrix, but the frame (hard bit to get) is there
Included a brand new drier to go with the old one and two compressors, one never fitted and the additional pulley for the front of 300tdi engine (I don’t know what you need for td5).
This is strictly COLLECTION ONLY. Please do not ask to post!! The pump is way way to heavy.
£550 - Warwick - Warwickshire just off the M40.
Hope the add meets the rules if not please let me know and I will amend ASAP
 @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #848689 8th Aug 2020 5:03pm
mk1collector
Is there a wiring loom with it? Ray
My build thread
Post #848698 8th Aug 2020 7:05pm
Steve_overland
I believe as you see it is everything you need... @steve_overland on Insta.
Post #848760 9th Aug 2020 8:16am
mk1collector
You need wiring for the fan and compressor which then plugs into the car loom and under dash loom. Unless your just replacing the parts on an existing aircon equipped defender obviously. Ray
My build thread
Post #848834 9th Aug 2020 2:10pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
If all necessary wiring present then Dibs please! Out at mo but, will PM later to confirm.
Thanks 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #848841 9th Aug 2020 2:32pm
mk1collector
I think v8 setups were different but I could be wrong. That’s if your fitting it to your 130 obviously Thumbs Up Ray
My build thread
Post #848884 9th Aug 2020 5:50pm
Steve_overland
That’s a good point hadn’t considered that bit.... @steve_overland on Insta.
Post #848885 9th Aug 2020 5:52pm
Mr Fudge
Interested - PM sent.
Post #848933 9th Aug 2020 11:03pm
Shroppy
Yes, I believe V8 air con set ups were sightly different but, my 130 will be running a slightly different set up so I can make it work Thumbs Up
I hope... 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #848947 10th Aug 2020 7:25am
Steve_overland
Hi all at the moment this is looking sold, will update when I know for certain... @steve_overland on Insta.
Post #848948 10th Aug 2020 7:35am
