Home > Puma (Tdci) > 2.2 TD4 - dead.. Fuse F4 goes immediately
Borbarad
Germany 2013 Defender 110 Puma 2.2 SW Fuji White
Hi,
I’m stuck in Sweden on my way back to Germany . 2.2 TD4 My2013, immobiliser deactivated
Out of nowhere everything went dead. After searching and trying I found that the 30amp Fuse F4 (under the seat) went.
Without .. you could turn the key but nothing.. new one in.. you could start again but in less than 10 sec it blow out again...
Really no idea where to search day looked at the main wireing seems all fine no...
Any ideas where to search ???
Otherwise the electricity seems fine... all on ifi turn the key.
B
Post #848123 5th Aug 2020 2:19am
Dinnu
When my 2.2 left me stranded (luckily I was not too far from home) I suspected the problem to be an immobilizer issue. But you already figured out that F4 is for immobilizer. 30A is quite a current, so without having an electrical manual, I suspect it is feeding a few components. I would check the cables between doors and bulkhead, and B post if you have a 110. Remember to check rear door too. Try to uncover the rubber boot around the cables, see if you have any chafing. Check also if the fuse blows with all doors open, vs the doors closed. If fuse does not blow, close doors one by one until you find the culprit.
I hope this helps. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848126 5th Aug 2020 5:13am
Borbarad
Thanks... the immobiliser is deactivated.. as it p.. me off once... I had checked the door cables but will do again.
However acc to Haynes manual Fuse F4 ( secondary Box under the seat) is for “Engine ECU/PCM”
B
Post #848129 5th Aug 2020 5:28am
Dinnu
I had a look at the electrical manual (for the first time Embarassed ) and you are correct, F4 is mainly feeding the ECM, but I see that it is feeding other relays and fuses. Are you good in reading electrical manuals? I got electrical manual for MY12, but most likely applies also to your vehicle as well. PM me your email address to send it.
PS.. now that I know more, maybe no point checking the door cables, sorry about that Embarassed 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848134 5th Aug 2020 6:20am
Dinnu
When I had the issue, someone suggested to me to check the harness by the rear engine lifting lug (left side). I understood that it is notorious for chafing there. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848135 5th Aug 2020 6:31am
Borbarad
Thanks... but I m totall lost here engine lifting lug????
Post #848136 5th Aug 2020 6:35am
Borbarad
Post #848138 5th Aug 2020 6:39am
Pacha
Red hoop that is slightly raised towards the rear of the engine/front of the bulkhead. Rgds.
Chris
Post #848141 5th Aug 2020 7:03am
Borbarad
By the way if I plug in a new fuse and try to turn the key it goes immediately off... so no chance to even try to start.
B
Post #848142 5th Aug 2020 7:03am
Pacha
 Rgds.
Chris
Post #848144 5th Aug 2020 7:05am
mk1collector
When our 2.2 did this it was the b post central locking wires broken and shorting together. Ray
My build thread
Post #848153 5th Aug 2020 8:21am
Borbarad
Im lost really... the issue starts with/ after the C2518 connector. If plugged in the ECU, the fuse goes immediately - if not plugged in it doesn’t.
So my hope was when I disconnect the every connector that is part of the C2518 cable the fuse should stay alive but it isn’t...
What can I do ???
Post #848362 6th Aug 2020 11:57am
Dinnu
Hi Borbarad,
As I check electrical manual I see that on C2518 there are:
1. Sensor Temperature Air Charge (T361)
2. Sensor Temperature Exhaust 1 (T551)
3. Sensor Temperature Exhaust 2 (T552)
4. Sensor Temperature Exhaust 3 (T553)
5. Sensor-Differential pressure (T398)
6. Sensor-MAF/IAT (T317)
7. Sensor-Heated oxygen(HO2S) (T131)
8. Sensor-Crankshaft position (CKP) (T102)
So do you say that you have disconnected all sensors right next to their connection, and with C2518 plugged back in the ECU, the fuse blows? If yes, then tat really points to a harness issue rather than a sensor issue.
I know that the Exhaust temperature sensors are connected right next to the gearbox to transfer box adapter plate. You need to take the seatbox lid underneath the chubby box to get to them. https://www.defender2.net/forum/topic73061.html Maybe you can update my thread with a picture once you are investigating there Embarassed
But I would also look at the Heated oxygen sensor... maybe the heater has shorted out? Would rule it out once it is disconnected though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848367 6th Aug 2020 12:25pm
Borbarad
Yep ... all disconnected and the fuse still goes... I’m checking the cables but really cannot See or feel anything.....
Tim
Post #848369 6th Aug 2020 12:34pm
Dinnu
Hmmm,
Sensor-Heated oxygen(HO2S) (T131) is powered through F16, which is rated at 5A.
Likewise, the MAF is powered through F15, also rated at 5A.
The Exhaust temperature sensors are not powered, and hence no fuses. Same for the air charge temperature.
The differential pressure is only 3 wires, unfused to the ECU on C2518. Similarly another 3 wires for the crank position, also not fused. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848370 6th Aug 2020 12:34pm
