Home > Puma (Tdci) > Help~2.4 shutting down as soon as it gets hot- rough idle-
Ben01
I haven't been on here for a few years as I got too busy with work...I couldn't recover my user ID for some reason. Happy to be back and have some time to work on my 90...not happy it is broken!
I'm chasing a problem where my 2.4 shuts down as it warms up after about 10-15 minutes of driving. This immediately follows a rough idle and power loss.
The problem first appeared after getting fuel at a dodgy station. I tried a few times to fix it and wasn't able to work on the problem for about 9 months, which may have made it worse??
Replaced with genuine or OEM parts:
Fuel pump, VCV, pressure relief valve, pressure sensor and crankshaft sensor, fuel filter
Breather hose was broken and patched. Now being replaced
I dropped the tank last night and there is some dirt in the tank and in the sender. I doubt it could cause this much of an issue.
Other potential problems:
The ECU is remapped and drove without a problem for 5 years. The EGR valve is shut off by the ECU. I do have a spare stock ECU, but need an AS10 (happy to buy one from a member).
I did have an electrical issue once where the battery connectors were loose. This was fixed by me.
On a few occasions while trying to fix this issue the temperature shot up and this was traced back to the relay under the driver's seat, which was replaced The problem hasn't been duplicating itself. Could this be caused by an electrical problem? Where should I look for a bad ground connection?
Codes
I am only getting a fault code through my Nanocom that the ecu lost communication, which I understand is a common code that doesn't mean much
What else could it be?
Post #848118 4th Aug 2020 11:40pm
Dinnu
Is there a temperature sensor on the High Pressure pump? Just guessing this, but since you mention that problem happens when it gets hot ( I hope by hot you mean normal working temperature, like 90 degrees celsius). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848128 5th Aug 2020 5:22am
bear100
There is a CHT sensor on the rear of the engine that will also give the symptoms you have....I know first hand!
A tell tale sign is the temperature needle moving when the engine is cold and ignition is on, although not always but usually seen climbing quicker than normal.
They are quite cheap and easy to fit so worth a go, lots of threads on here about it
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #848158 5th Aug 2020 8:37am
jst
By hot do you mean to the horizontal position or needle above into the red? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #848170 5th Aug 2020 9:24am
Ben01
Normal working temperature. I believe the pump should be ruled out.
Post #848199 5th Aug 2020 12:37pm
Ben01
Thumbs Up
thanks I will research and likely replace as it is cheap/easy. i didn't notice the temperature moving quicker than normal
Post #848200 5th Aug 2020 12:40pm
Ben01
horizontal position and/or after about 10-15 minutes of driving (sometimes less)
Post #848201 5th Aug 2020 12:41pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Thumbs Up
Good place to start - in my case I had a very minor radiator leak, climbing hills gave me a "dirty fuel" type misfire, 200 miles cruising at 70 ish down the Motorway - no problem, heavy A road traffic misfire again. This was one journey from Scotland to home. CHT sensor was doing its job, protecting the engine from overheating due to low coolant.
Thumbs Up Just because you're offended doesn't mean you're right.
Post #848231 5th Aug 2020 3:50pm
Ben01
I had a coolant leak previously which was traced to a hose. Should I flush the system now, or not needed? Would I still be having problems with the sensor?
Post #848232 5th Aug 2020 3:53pm
shropshiredefender
Frankly I don't know.
But the symptoms that you describe point to the CHT sensor either doing its job properly or doing its job because it's faulty.
It does not throw any fault codes and is difficult to diagnose, replacing it is relatively cheap and easy. Just because you're offended doesn't mean you're right.
Post #848238 5th Aug 2020 4:19pm
Ben01
Update...CHT sensor replaced, thermostat replaced, MAF sensor, MAP sensor, tank cleaned, Ecu replaces. I still have the same problems. Where to look next? No fault codes are coming up on the Nanocom.
Post #864764 1st Nov 2020 2:09pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
How does your coolant level look? Often the cap won't hold pressure and the coolant can boil. the temp gauge on the dash may not show this as it doesn't move until the temp is extreme...
 Roaming around 🇳🇴🇨🇭
Post #864767 1st Nov 2020 2:54pm
Ben01
Coolant level is ok. I just flushed the system.
Post #864776 1st Nov 2020 3:54pm
Spurge
United Kingdom 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
I've just sorted one that is very similar, clean out swirl pot in the fuel tank and replace the fuel filter head, there is a membrane in the filter head to bleed out air, this was blocked up on the one I've been on with so air couldn't escape the system. Bearmach do the filter head.
Post #864900 2nd Nov 2020 6:59am
Ben01
I will try this next. Still no codes.
Post #869977 27th Nov 2020 6:07pm
