Home > Puma (Tdci) > I have a rattle! **SOLVED**
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Well, not surprisingly after only 200 miles in the new XS DCPU I have developed a rattle. In the cabin, it sounds like its coming from the rear 3 seats. I can describe it as metal rubbing on metal producing a high pitched sqeaking sound.
I have given the seat fix points a going over and all tight as a drum. Rear sliding windows are OK. I have refixed the spare wheel and thats good to go... no issues there. I can't replicate it by having a bounce round on the seats. Might be a rubbing noise from underneath the vehicle maybe? Got it on the ramps and had a nosy at all the bolts visible underneath and given everything a good tugging, all seems solid.
Rear tilt is solid too... nothing rubbing there. Its well anchored down and the rear metal join strip is insulated from the cabin with 5mm of foam.
Starts rattling whenever you go over slightly bumpy ground, pot hole etc. Would drive me batty on a long haul. Has anyone got any suggestions on this one? Trying to avoid trips to the stealers. Have also heard a twangy spring noise at the same time. Not sure whether the two are related.
Post #79966 12th Jul 2011 5:56pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
We had the rear seats replaced twice in our 110 because of a rattle, all under warranty Smile The dealer did it without a fuss, might be occasional problem.
Hope this helps
Jack
Post #79967 12th Jul 2011 6:02pm
Martyn
Well, Im convinced its that area....
Post #79968 12th Jul 2011 6:05pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Have a look under the vehicle beneath the rear floor plate.There are suprort brackets going up from the chassis.I had to sandwich a rubber gasket between the the floor and these support brackets,and the chip-monks have since left the vehicle. Puma 110 SW
90 V8 SOFT TOP
Post #79970 12th Jul 2011 6:21pm
bob neville
Martyn
Couple of areas to check on the DC.
1. Look at the area where the seats are supposed to touch the floor at the back. They have adjustable feet and they may not be making proper contact.
2. Even though the seats are fixed, they have the ability to be folded down if you undo the retaining brackets at the back. The swabs are released by a pull handle that unlatches a claw from a bar. This can squeak.
One thing to be aware of before you start undoing brackets attached to the seat backs, they can be pain in the proverbial to get back in - I always spent many a happy hour trying to get them fitted again Thumbs Up
Good luck
Bob - no rattle from the rear seats not but an annoying squeak from the door trim behind the drivers seat Laughing
Post #79971 12th Jul 2011 6:25pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
ssshhhhh, 180 miles on mine now, and no squeaks/rattles yet (don't tell anyone Thumbs Up )
Rolling with laughter Mark
2011 110 XS DC
Stornoway Grey
Post #79984 12th Jul 2011 7:57pm
spudfan
Ireland
You should not post information like this-your vehicle might be stolen. Rolling with laughter 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #79999 12th Jul 2011 10:12pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had a number of squeaks and rattles that nearly did me head in on long drives across Europe.
One of the most annoying ones came from the rear seat (middle row). On the left side, the 1/4 seat would squeak when it rubbed against the little metal bar that pops up from the floor when you fix the seats in the upright position.
I applied some lithium grease to the bar and contact points (later used silicon spray), and this did the trick.
Because of the acoustics in the 110 I couldn't track the source down for weeks.
I've also had the rear door squeak, where it was rubbing on the striker panel. Had to be re-hung properly by the dealer.
Post #80007 13th Jul 2011 6:13am
Martyn
Righty, the problem is the wheel mounted in the back. LR in their wisdom have used the 4 smallest adhesive pads they could land their hands on to keep the wheel off the back. The spigot is smaller than the hole through the wheel centre so even doing it up tight, after a few days the wheel moves half inch left or right and moves off the sponge pads. Tyre rubber creates a high pitched "chipmunk" noise which booms through the cabin.
I cut a 70x60cm piece of 6mm thick rubber and popped a hole in the middle, fed it over the spiggot and tightened her up. All four contact points are now well covered and its a quiet, creek free drive! Thank god, its driven me insane the last 2 weeks. Crying or Very sad
Post #80653 17th Jul 2011 1:59pm
Zagato
Apart from an occasional clutch pedal squeak which has now gone the Defender is the only car I have owned that does not make a noise, not a vibration, gender, squeak nothing Confused Go figure that for a LR with hard suspension - give it time Sad
Post #80738 18th Jul 2011 7:13am
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Give it time Zag!
I have a couple of rattles. One is from the rear, either the left side window is rattling or the rear left seat is rubbing against something when it's in the folded position. I've also a squeek in the front from the left hand side. I thought it was the passenger seat, but it seems to be the passenger door card rubbing against something.
Nowt serious by the looks of things, but irritating.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #80844 18th Jul 2011 6:19pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The door card can rub against the seat box, especially if carpeted. I just spray some silicon spray on the door card. Gives a good finish that is dirt resistant and stops the squeak. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #80849 18th Jul 2011 6:28pm
DefenderOfTheEarth
None on mine. Apart from the clattery engine and rather "firm" ride Rolling with laughter Defender 110XS SW gone... now VW California 180 4 Motion.
Post #80854 18th Jul 2011 6:32pm
cinstone
That's great! Tar very muchly!
Post #80865 18th Jul 2011 6:52pm
Zagato
How many miles has yours done now Chris? You haven't had any probs yet have you Thumbs Up
Post #80886 18th Jul 2011 8:10pm
