Home > Td5 > Rear door lock - 2003 TD5 90
Gareth
How do I change the lock barrel in my 90?
I have done both front doors and fitted a new steering ignition lock, because the old locks were seized and the ignition lock was temperamental. I’d really like to fit a new matching barrel to the rear door.
Many posts refer to a brass pin to push in on the outside of the casing, and pull it out with the key. I have cleaned all the crud off and cannot see a pin to push in. It looks like the lock assembly is fixed together with rivets, do I need to drill these out?
Puzzled at the moment!
 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #845276 22nd Jul 2020 3:13pm
dorsetsmith
depends on the age of the door/lock.
Earlier versions have a short barrel and there is a hole in the outer tube that houses the barrel. You poke something into the hole and depress the plunger allowing the barrel to slide out.
Later locks use a longer barrel and, as a result, the plunger is much further into the tube. This means that the hole is actually inside the lock mechanism and you have to access it through the slot in the top of the mechanism where the central locking lever would/does come through. On this type you can remove the barrel without removing the lock mechanism although you still need to remove the door card.
Post #845282 22nd Jul 2020 3:52pm
Gareth
Ok that’s great, thanks very much. I must have the later type. It’s all back together now, but will whip the door card off again tomorrow. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #845302 22nd Jul 2020 5:00pm
4RF RDS
Re: Rear door lock - 2003 TD5 90
Pretty sure your hole to release the cylinder is corroded over. Have a closer look and drill it out if needed. Thumbs Up Good luck
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #845357 22nd Jul 2020 8:05pm
tuko
Sweden
Would never have thought or seen that, now I can leave the drill on the shelf. Laughing
Thanks. 300Tdi power Series 3 88"
Ex-MOD 1992 110 Heli Support Unit
Post #916732 13th Aug 2021 12:38pm
