Home > Technical > Rear Shock Upper Mount Movement
rallysteve
I have noticed that both of the upper rear shock mounts on my 110 seem to have developed some axial movement. The bushes look in good condition and there doesnt seem to be any movement between the shock and the bush. All of the movement of the shock seems to be axially along the shank of the shock mount. The nut and washer are correctly in place on the mount but there must be close to 10mm of play on one side. It is almost like the shock is too narrow or the plain shank of the mount is too long. This seems to have been a recent development though as it hasnt been an issue previously and I have not touched the mounts or shocks since they were fitted in 2016.
Any ideas what the cause could be?
Cheers,
Post #844820 20th Jul 2020 8:44am
Grenadier
Could the bolt be too long, thereby not allowing the nut and washer to seat themselves properly against the damper/Bush? Or perhaps you need a spacer because your brand of damper has a fixing point that is too narrow for the vehicle’s mounting bracket? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #844831 20th Jul 2020 9:39am
rallysteve
Thanks for the suggestion. However, the damper and mount are both genuine items and there was no play at all when they were first fitted and seem to have been fine for 4ish years and about 30k
All i can think of is that the shoulder on the mount has some how worn away or the metal tube in the centre of the bush has worn. I will take them off and have a look in the near future.
Cheers,
Post #844840 20th Jul 2020 10:30am
Replace both, job done.
The mounts aren’t hard work to replace, in fact the bush is the bigger problem. TheThunder Rolls🇬🇧🇺🇸
Post #844841 20th Jul 2020 10:55am
jst
the top mounts as an eye system have never been great, i use Gwyn's pin/pin setup.
ran the +5" on my challenge truck for 5+ years with no problems, now running std height shocks on his std height pin/pin setup with OME pin/pin shocks on my more road going defenders.
far better solution and less stress on the rubbers.
https://gwynlewis4x4.co.uk/product/rear-st...nt-gl1171/ Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #844873 20th Jul 2020 2:43pm
^^^ Those look good, hadn't seen those! Thumbs Up
Do they use existing holes or does the chassis need drilling?
Post #844891 20th Jul 2020 4:20pm
Hufflepuff
It uses the existing holes, so no problems there. However on the Td5, at least with the twin hole setup (https://gwynlewis4x4.co.uk/product/rear-ch...ue-gl1062/), you have to reposition the fuel filter further forward, as it interferes with the brackets. Gwyn can supply the necessary hardware to do this - my only mild concern with it was that it puts a bit of additional stress on the fuel pipes, as they are not in their natural position. 2005 Td5 90 XS
1989 V8 110 CSW
Post #844893 20th Jul 2020 4:28pm
Grenadier
OMFG, there are so many awesome little upgrades out there. Why do I always find out too late. Fitted new shocks a year ago. Big Cry Monsieur Le Grenadier
Post #844905 20th Jul 2020 6:05pm
jst
yes they do Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #844909 20th Jul 2020 6:30pm
jst
for the +5 you need this, its not needed on std height ones. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #844910 20th Jul 2020 6:30pm
jst
Std length shocks, tdci fuel filter in std place
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #845237 22nd Jul 2020 11:37am
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #845249 22nd Jul 2020 1:07pm
rallysteve
Thanks all, looks like Gwtn Lewis will be getting a few orders!
I presume front shocks fit these fine for standard height application?
Cheers,
Post #845253 22nd Jul 2020 1:21pm
jst
Just had another set delivered to go on the 130. Ome 60147 for this application. But yes std length.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #846502 27th Jul 2020 7:36pm
markb110
You should try doing this with the added fun of a full external Safety Devices roll cage..... Whistle
Post #846509 27th Jul 2020 7:49pm
