Home > In Car Electronics > Heated Seat Wiring Runs |
8619simon Member Since: 04 Nov 2016 Location: North Wales Posts: 247 |
I had a similar issue when fitting my Raptor dash. I ended up running some multi-core cable from the battery box out through grommet that the earth cable comes in, along the top of the chassis leg and up the outside of the bulkhead by the heater box. I then went along the top of the bulkhead to where the speedo cable comes in through a gromet in the bulkhead, I followed this in to behind the instrument cluster and then along the back of the dash to behind the raptor dash.
Not too bad but I didn’t want to keep doing it so running multi-core means I have spares wires as and when I add more switches. |
13th Jul 2020 7:18pm |
