![]() | Home > Maintenance & Modifications > Electric Window and Central locking Harness |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
You'll need the door harnesses and loom that runs from drivers under seat to rear door and across to other rear door.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
If you have the connectors in the harness then you should have all the "body" side wiring.
So you just need to get the door looms, is that correct? ![]() ![]() |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
This is what I have so far.
![]() ![]() ![]() So the first photograph shows at the bottom left the 3 wires going into the connector and a single wire coming from the other side going to the interior light switch. I can’t find any sign of the 3 wires on the other side, just the single wire for the interior light switch! Apologies for my poor photographic skills. |
Would it be too much to hope for that the alarm module ( 2014 Puma ) actually has the CDL relay fitted.
It is the newer module not the 10as. |
I think what Romadog has said is what I need.
You could do a quick test to see if the central locking is enabled.
With a meter or a test bulb, check if you get a 12V pulse across the plain orange and plain pink wires when you press the fob buttons. You can do this at the black plug at the door or the 3 pin connector for the rear doors in the seat box. You would be changing the current rear door loom with the single purple/blue wire to the one populated for the motors as well (orange and pink). The "full" loom for this is YMM000341 or LR016438 or LR030062 ![]() ![]() |
Forgive my ignorance Martin but is it to test each wire
when earthed or bridging the pink and orange wire then pressing fob? |
If you put the meter/bulb across the pink and the orange, then you'll get a +12V reading one way (say, lock) and -12V the other. Or a flash from the bulb both ways
![]() So for clarity: across the two wires, not from each to ground ![]() ![]() ![]() |
Right, got it😳
