![]() | Home > Tdi > No horn |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Part No. RTC6461R cost approx £7.50 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
No relay with original horn(s), so likely an aftermarket horn. The clicking that suggests the column switch is OK, you need to check the input to the relay (fuse?) and output.
Could still be a failed horn but likely you're not using the original system. ![]() ![]() |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 ![]() ![]() ![]() |
It has been moved due to full-size intercooler, there’s a relay in the engine bay that doesn’t seem to relate to anything, so it may be for the horn.
I’ll have to have a proper look at where all the wires go. |
