![]() | Home > Technical > 4000kg towing on coupled/air brakes, trailer types etc |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
My personal view has always been that if you want a higher authorised MAM than 3500kg then you really should be looking at a different vehicle to a Defender, since essentially it doesn't have the reserve strength for higher operating weights.
This is also the reason why I've always felt that 6-wheel Defenders are actually a waste of time, unless all you want is the visual impact, since the basic vehicle is simply not robust enough for the mass. By the time you've strengthened the chassis, axles, and driveline, you would have been better off starting with a stronger vehicle. There can also be little doubt that a Series vehicle is actually stronger than a later coil-spring vehicle, and, especially off-road, the leafers are driven more sympathetically than the coilers because the driver feels far more discomfort. Overall I don't personally really see any point in going through the pain of upgrading a Defender to tow a coupled-brake 4-tonne trailer just for the sake of the extra 500kg. Buy a Unimog or MAN or Merc 4x4 and tow 5 tonnes or more safely instead. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1238 ![]() ![]() ![]() |
Not quite a Defender but does state 4t quite plainly for tow capacity. No mention of extra braking requirements. ![]() Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
