Home > Technical > Another power window question
nieldm
Can I get a bit of advice? The drivers side window has stopped working again, drives me nuts. I want to fix it properly this time.
I tested the switch by using the working one on the passenger side. I have the door card off and there is 12v at the connectors below the motor, so no broken wires. Would I be correct that it has to be the motor? Photo attached - can I swap out the motor (if the culprit) for any other or do I need the entire kit for the door?
Post #841489 3rd Jul 2020 12:05pm
It may not be the motor. If I recall correctly the motor is live all the time and the switch grounds one or other of the motor terminals. If one of the wires in the rubber conduit has broken (the usual problem) you may still read 12V on both motor terminals due to the low impedance of the motor windings.
I sugggest reading the voltage on each terminal at the same time as you press the switch, or take the reading across the terminals (which should be 0V unless you press the switch, when you should see something approximating 12V).
Post #841492 3rd Jul 2020 12:10pm
nieldm
Thank you for the quick reply! I should have been more clear. I get 12v measuring across the terminals when I press the switch and 0 otherwise. It doesn’t look like either are permanently live though, ie either terminal to earth is 0v
Post #841496 3rd Jul 2020 12:17pm
Martin
Site Admin
Photo added to your post - for clarity you've got an aftermarket kit not factory.
Measuring across the feed to the motor, you should get 12V with the switch in one direction and -12V the other. If this is the case (it sounds like it is) then it's not the supply to the motor, it's the motor.
You may be able to unjam/free off/service the motor, or you will have to source a replacement. Quite what that replacement would be for your aftermarket kit I don't know, sorry.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #841502 3rd Jul 2020 12:32pm
nieldm
Decided to strip the motor to see if there is anything obvious. It looks like the brushes are fouling on the housing and causing it to stick. Would I be correct?
Post #841505 3rd Jul 2020 12:36pm
Martin
Site Admin
Looks like a generic universal kit, loads of the same parts on Aliexpress and here in the UK:
https://www.hawkcaralarm.com/catalog/car-v...-2-windows
Shouldn't be impossible to source a motor if needed.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #841507 3rd Jul 2020 12:37pm
nieldm
And yep, well aware it’s aftermarket.
Can I replace it with a standard motor or do I need to change the entire mechanism?
Post #841508 3rd Jul 2020 12:38pm
Martin
Site Admin
Assuming the mechanism isn't at fault (perhaps detach at the winder and try it, and run the motor removed from the gearbox?) then you should be able to change the motor on its on. Get any part numbers/markings off the existing motor whilst you have it unbolted Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #841511 3rd Jul 2020 12:40pm
nieldm
No, the mechanism works. Even turning the motor by hand with the cover off feels “lumpy”, lots of resistance.
Now if I only had a manual winder handy I could at least do a temporary fix...
Post #841512 3rd Jul 2020 12:42pm
I suspect the label on the motor is the key to the problem. Rolling with laughter
Post #841516 3rd Jul 2020 1:00pm
