Home > Tdi > Heavy Steering
shaggydog
Heavy Steering
Hi all,
Using the Land Rover again after a while way from her (too long in fact) but the steering seems to be far stiffer than I remember.
In fact it almost struggles to self center on roads which makes me think the power steering is not quite what it was.
I have not touched it in the entire time I have had it, not even changed the oil or topped it up its just always worked fine.
I know its not just me having foggy memory as it used to, at stationary, be able to turn the wheel with one finger through the spoke of the wheel whereas now its noticeably heavier.
Would an oil flush and change be a good first port of call or should I be looking elsewhere? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #841260 2nd Jul 2020 10:36am
sako243
Change the fluid and rebleed. I was thinking my pump was knackered but after having to do an engine swap the difference was profound due to new fluid. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #841275 2nd Jul 2020 12:02pm
jst
Any fluid movement in the res engine running? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #841291 2nd Jul 2020 1:13pm
Tommybahama32
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Hi,
might be worth checking the U/Js on the lower shaft between the column and the steering box, they can seize up, especially if its been stood for a while. Oh and tyre pressures. Very Happy
Post #841300 2nd Jul 2020 1:55pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Mine sounds very similar , I had a leaky box , put a recon unit on and it’s struggled to self centre and harder to steer . I tried replacing the fluid and adjusting the nut for tightness and it’s made no difference , I’ve now learnt to live with it but it’s certainly not as pleasant as it was !
Look forward to hearing the fix ! https://www.instagram.com/hustynminepark/
Post #841302 2nd Jul 2020 2:00pm
Mdm
check pump is working
oil swap and flush wont hurt as nobody swaps the oil..
check oil for metal!
then it will most likely be a seized steering column uj.
remove and replace if so as once seized they will only do it again even if you free it off
Post #841324 2nd Jul 2020 4:10pm
benniferj
I had a friend that recently had this issue with a VERY seized UJ on either track or tie rod, cant remember which. He was shocked it didn't snap as did not move by hand at all Insta: @thebenjordan4x4
Post #841327 2nd Jul 2020 4:14pm
jst
if its a seized uj you will prob hear the pressure relief valve in the PAS system, which means pump is working. seized UJs tend to make it lumpy too. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #841343 2nd Jul 2020 5:16pm
