Home > Puma (Tdci) > Starting Problems |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Check the tightness of the relays in their connectors under the seat.
27th Jun 2020 5:22am |
jbullis Member Since: 28 Apr 2013 Location: Jonesborough, TN Posts: 24 |
I tired the relays, they are all pushed in tightly.
27th Jun 2020 4:10pm |
This thread may help:
https://www.defender2.net/forum/topic51335.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Jun 2020 4:18pm |
I've been messing with it enough to determine that if I don't press the unlock on the immobilizer(if its not set), I have to go into the on then off again exercise. If I preemptions the unlock it fires on the first turn. Will changing the batteries in the FOB correct this? Or do I need to go into a different direction?
27th Jun 2020 10:33pm |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 |
Do you have a second fob? If yes, have you tried starting the vehicle with it?
I have one fob that starts my vehicle as it should and a second fob that only operates in a similar way to what you describe. I replaced fob batteries, tried re syncing the fob, but no change. Posted on the forum about this, but didn't get a solution. Tried a main dealer, but they wanted my 90 (MY 2012) in for investigation at their hourly rate, so I decided to live with a second fob that doesn't do what it should. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
28th Jun 2020 6:36am |
Good point. I only have 1 Fob. I’ll order another. I’ll also see if I can use the Nanocom to to reprogram my current Fob too.
Thanks |
28th Jun 2020 12:51pm |
After doing more research and messing with my Nanocom, in the 10AS, set the passive imbolize off. It fixed my problem. Help this can help others.
Click image to enlarge |
30th Jun 2020 12:47am |
