Home > Td5 > Part numbers for Defender ECUs |
I put everything from under the seat between my seats on the bulkhead. Only the diff lock sensor cable has to be extended.
There are 2 versions off the engine ECU the old and the 'new' I believe there is no technical difference between the disco and Defender it's just the software. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
26th Jun 2020 9:48pm |
Shuggy110 Member Since: 25 Mar 2018 Location: Perthshire Posts: 58 |
It depends on whether you have a 10p or 15p engine, and whether it’s an auto or manual. The ECU needs to match the engine but if you try to put, say, an auto Disco engine into a manual Defender you will need to change the ECU and have it coded to the Td5 injectors. There is loads on this if you Google it. Replacement ECUs are getting more and more expensive - perhaps up to £250 right now. You may be able to get some success if you talk to one of the site sponsors such as Gareth at Empire Tuning.
27th Jun 2020 10:54pm |
