Home > Puma (Tdci) > Fault code reader for orange engine management light |
Shuma Member Since: 27 Jan 2016 Location: Strathpeffer Posts: 46 |
Anyone in the Inverness area got a fault code reader I could hire / borrow/ use? I have the orange engine management light on on my 2016 Puma 2.2 and want to know what might be wrong. I guess it will be MAF or EGR related as it seems to be running well and just had all the oils done recently. Is there a reader I could purchase for under £100 that would help me diagnose the problem?
23rd Jun 2020 2:59pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2001 |
https://www.defender2.net/forum/topic68908.html?highlight=elm327
Have a look at this thread. You can get cheap ELM 327 readers plus free phone apps to read and delete (after recording) generic codes for a few pounds. I have athe OBDLink LX . See my post half way down. It’s great for having permanently in the car. I now also have a nanocom as well but that’s kept at home and not cheap but delves into much more specific defender diagnostics. If you have an iPhone or iPad you need to get the right elm327 plug in. |
23rd Jun 2020 5:32pm |
Thanks for the information will take a look at the ELM 327
24th Jun 2020 7:00am |
Hi Ian
Thanks again. It will be 2 weeks before i can get the tests done so will get back to you then. Appreciate your help. |
24th Jun 2020 9:15pm |
Ianh
I am back home this week and can take a look at the fault codes. Typically the engine management orange light is no longer lighting up when I drive the vehicle!! I have purchased one of the cheap OBD Connect, fault code readers. Its the wi-fi one for use with an i-phone. On the instructions it says to connect to an app of my choice with common choices being TORQUE-Dash Command-OBD Fusion-OBD Auto Doctor Any suggestions which app suites the defender the best? |
6th Jul 2020 11:43am |
These are generic code readers so all much same, I have an Android phone but dash command on an iPhone should give you access to current and historic fault codes. Plus the ability to clear them once you have recorded them. That should give insight into what triggered the check engine light (CEL) / malfunction indication light (MIL) . If your light has cleared and not reappeared then it’s because your engine has run through several diagnostic cycles without the issue arising again, or arising insufficient times to trigger the CEL/MIL light to come on. Different faults have different trigger points. Some don’t trigger a CEL/MIL at all.
If you have had a lot of stop starts / short journeys many different components could have got a bit “ gunked up” ,then a long journey cleaned them out, hence the CEL/MIL not coming on again. Once scanned post the codes on here, and anything you have felt seemed different when starting, driving etc and people will advise on the right order of things to check. Ps don’t panic if there are lots of codes, lots of times they are old but not cleared at service intervals. When you have them recorded you can clear and then keep a regular check to see if any new ones appear, which can help identify an intermittent issue that points to a component degrading. |
6th Jul 2020 6:19pm |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 |
Can the engine management light be reset without the aid of a diagnostic tool? I read somewhere if the battery is disconnected and left for a while this works.
14th Jul 2020 11:34am |
Well I finally got the code reader hooked up and the fault code was P0404 Exhaust Gas recirculation "A" Control Circuit Range / Performance.
The fault has self cleared. It was displayed as a "stored code" No pending codes and No permanent codes found. Is there anything I should be doing to the EGR valve, or just leave it as it is at the moment? cheers Click image to enlarge |
14th Jul 2020 12:38pm |
I would leave for the moment but start to prepare for an EGR replacement at some point. look at the prices and sources for the part, understand the process and the tools required, and decide if it’s something you are happy to do or identify a few local independent defender garages and get a quotes for the work.
Note:- the egr valve on the 2.2 is made by pierburg, supplied to ford and has FOMOCO cast on it. If bought as a genuine landrover part all they have done is put it in a landrover box... and doubled the price to do so. If you look at the valve you can see the pierburg part numbers on a labels on the side facing you as you look from the near side wing. I obtained a pierburg one direct for £99 inc postage. A local defender specialist quoted 2 hours to fit. I fitted myself, more as a challenge than a cost issue, all in all about 5 hours work, interspersed with a couple of hours of tea breaks to calm my frustration on how the limited space made a simple job so hard to do. I think I could do it in 2 hrs now. So keep monitoring fault codes, listen out for the quite noisy cycle the egr valve goes through when the engine is switched off after most non short journeys. Noting it does not do it every time, but if it does not do it at all it’s a good sign the egr is failing. Look out for a slight hesitation / hiccup when pressing the accelerator after a gear change, or for the engine not starting first time . All are indicators the egr valve is not running smoothly and if it does fail in the wrong way it leaves you in limp mode, which you can clear with your scanner now but not ideal. If any of these symptoms happen then it’s time to change egr. |
15th Jul 2020 12:40pm |
Thank you very much for the information. I expected that the part would have a Ford transit equivalent and be a lot cheaper!
I have only done 20k miles but the last year has been much shorter journeys and was expecting some sort of EGR issue to emerge. Im glad that this fault seems easy to fix and is not massively expensive. I will replace the EGR valve myself so all advice most welcome. The code reader is a handy tool so thanks for all the advice. |
15th Jul 2020 10:31pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
Gents
Is there a dedicated pin for the MIL on the instrument cluster? Short story I would like to permanently turn it off. 2.4 tdci Thx Puma 110" SW ............................................................. Earth first. Other planets later |
26th Oct 2023 5:48pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
No, it's sent on CAN from the engine ECU. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Oct 2023 5:57pm |
Is it a led? Puma 110" SW
26th Oct 2023 7:59pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1051 |
I think the engine light is on because there is some sort of a fault that needs fixing.
Removing the indicator is not fixing anything and (officially at least) any inspection would normally involve seeing all the lights illuminate in the startup test phase to ensure all fault indicators are working as it should. |
27th Oct 2023 6:40am |
