Home > Puma (Tdci) > WIPER BOX
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
WIPER BOX
Hi all is a td5 wiper box and cable easier to change than a Tdci 2.4 ?
Post #838788 21st Jun 2020 6:37pm
jst
Nope! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #838793 21st Jun 2020 7:18pm
bunnyman
Cheers James did my td5 about 6 years ago and the wipers have just stopped in my Tdci
Post #838800 21st Jun 2020 8:10pm
Try pulling up the outer rubber seals on the spindles first and lube well.
Mine had this, it was the spindle seizing due to being so dry and the weather brought they about as well as no lubrication.
Once done, turn them on and nudge them and you should find they get going again and then keep lubricating well.
I found there was no other problem with mine than this when I had the same problem. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #838803 21st Jun 2020 8:37pm
apachecow
1999 Defender 110 Td5 CSW Rutland Red
I thought it was one of the easier jobs I've done on my TD5. Bit of dash disassembly - changed cable, wheel boxes and park switch thing. Swapped for new arms and flat blades. Much better and didn't take an hour and well worth the £100.
Post #838807 21st Jun 2020 8:56pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Re: WIPER BOX
Are you implying that over the years improvements have been applied? But you are talking Landrover?
Not much difference though. Never forget: cars have owner, Landrover have field service personnel.
Post #838850 22nd Jun 2020 9:02am
