Home > Tdi > Boost Pin installation - OIL !!!!
frenchy
So the Morgan Hill boost pin turned up today.
Installation took a little longer than the 10 minutes I've seen on YouTube (expansion tank in the way etc etc)
However. on removing the top cover there was oil on the diaphragm and inside the pin cylinder.
I'm pretty sure it shouldn't be there Shocked
the oil was black and quite 'fluid' i.e not gunky
BTW, didn't notice any real performance difference, but no black smoke either!
 2000 D2 TD5 - ahhh bless
2006 D3 - no longer with us and sadly missed
1997 300tdi d90 - now with electrics that work!
- now with a brand new custom made soft top fitted
…...…...............….new chassis now all fixed and driving like new
2010 D4 alas no more, but a lovely colour (Nara)
2016 D4 battery magically fixed with NOCO charger
Post #837686 16th Jun 2020 10:35pm
frenchy
does anybody know...…
Question where it is likely to have come from
Question is it a serious problem
Question how to remedy
thanks Thumbs Up 2000 D2 TD5 - ahhh bless
Post #837812 17th Jun 2020 2:22pm
donmacn
Ah, I remember doing this.....
I took the lid of mine, and it wasn't just oil but all sorts of muck and grit...not pretty. I can't remember if I took pics or not, but if I did I'll post them.
I think what's happening there ( and in my case ) is that the oil is coming from the fuel advance pipe at the turbo. If the crankcase cyclone breather thing on the driver's side of the rocker cover is old/ineffective then it's directing more oil than it should back into the air intake pipework, just before the turbo. This then enters the advance pipe, and will make its way up to the fuel pump.
I think I gleaned that its something of a trait in the 300Tdi, that the crankcase breather isn't a great design, and that it's all a bit oily.
I also had a couple of holes in my advance pipe which wouldn't have helped - delivering no fuel advance at all, and allowing cr*p to get into the diaphragm cover.
I don't think it's particulary serious, assuming that the diaphragm isn't holed. How to remedy - you could replace the crankcase breather (allisport do a shiny and expensive allu. one... I'm guilty of that).
Then, you could disconnect the breather pipe from the air intake to the turbo. THis is the sort of mod that leads to 'catch cans' etc. and that's a whole other can of worms.
(Edit - just looked more closely at your pics - it's slightly strange that the oil is also on the underneath of the diaphragm - is it holed do you think? or is it sealing effectively against the top of the pump?
Also - you can quite easily take a look at the intake pipework, just before it enters the turbo. Just to see how oily it is. Might just be a pointer. If it's clean - which is unlikely - then you'd need to look for other explanations. )
(2nd edit - just to stress - have a good look at that pipe that runs from the turbo to the fuel pump. It can chafe against several things along the way. If it's got holes in it, that's going to upset your fuel delivery.
I also found that my pipework was a bit broken between the T piece where it meets the turbo, and the wastegate actuator. Awkward to get to, because it's underneath, but again that would affect the wastegate operation.) Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #837823 17th Jun 2020 3:36pm
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
The breather cyclone is very easy to clean as it is basically an empty container. Just take it off and leave it standing in paraffin over night with the pipes that should clear any sludge when refitting use a new o ring to seal or you will find it will probably leak
Thumbs Up simon
Ps when I did mine I didn't notice any great performance increase there are a few threads on here and the general consensus is its helps to do the pin when used with other "engine enhancements " but these ain't racing cars Rolling with laughter WHAT COULD POSSIBLY GO WRONG
My sky lantern petition
http://chng.it/HJXmZC47
Post #837846 17th Jun 2020 4:34pm
donmacn
Thought I had it here somewhere.
This is what I found when I took the top off my pump. Just horrible.
As RedZep has said, you can clean the breather, or I forgot to say that the standard plastic ones aren't that expensive - about £20 from memory. Donald
in the past..
Post #837856 17th Jun 2020 5:25pm
frenchy
thanks for the replies.
TBH, the car is driving OK, pre the boost pin installation.....I was hoping for a 'little' bit more
Oil where it shouldn't be just concerns me. I have had a scout around and am I right in thinking the small diameter pipe from the top of the boost pin housing connects to the 'outlet air' side of the turbo?
Took off the air inlet pipe to the turbo and that is a wee-bit gunky.
The outlet of the turbo is gunky too, as is the intercooler and the inlet manifold.
Is the turbo the 'weak link' in all of this, leaking oil which the contaminates all inlet & outlet lines.
I was thinking of fitting a replacement intercooler soon as the existing looks a bit haggered, but now I'm thinking it will get instantly gunked up!!!!! 2000 D2 TD5 - ahhh bless
Post #837900 17th Jun 2020 7:29pm
donmacn
You've got similar thought processes to where I was a little while ago. Trying to get a little more oomph from an older 300tdi.
When I saw all the oil around my turbo hoses, my first thoughts were that the turbo itself would be leaking, but the replies suggested not, and that it would most likely be coming from the crankcase breather.
As I said above, you could clean out the hoses: filter to turbo; and the ones to/from the intercooler; divert the breather output into a temporary 'catch can', run it for a wee while and see if things oil up again.
I think it's possible for the turbo to leak oil though, and that can cause more serious problems - but it wouldn't cause oil on the inlet side.
The advance pipe is the small diameter one you've mentioned. As the turbo spins up and creates pressure, this enters the advance pipe and flows to the boost diaphragm. Pressure pushes the diaphragm (and therefore the boost pin) down. This allows another pin (whos name I forget!) to come out more and supply more fuel. This is why it's also important to check that advance pipe for holes - if it has small holes, the pressure doesn't get to the fuel pump diaphragm, and no matter how good the boost pin is, it won't be working to its full potential. Donald
in the past..
Post #837909 17th Jun 2020 7:57pm
Retroanaconda
Oil in the intake system is entirely normal on a Tdi, they’re renowned for it. When I got mine I was convinced it was on deaths door with the oil I found in the pipework. But 240k later it’s still chugging along just fine. A little oil goes a long way when it’s aerosolised like that.
As above it’s primarily from the crankcase breather which isn’t the most effective design.
Post #837940 17th Jun 2020 9:29pm
frenchy
Thanks folks,
bit of stripping, inspecting & cleaning to do over the weekend!! 2000 D2 TD5 - ahhh bless
Post #837953 17th Jun 2020 10:32pm
frenchy
Weekend work done.
Took off expansion tank & air filter box, then opened the bonnet all the way to the windscreen and access was great!!!!
Took off and cleaned the air pipework from filter to turbo inlet - all a bit mucky near the turbo end, downstream of the crankcase breather inlet.
Vacuum line from turbo to boost pin housing looked damage free and clean at both ends
Checked diaphragm and it appeared oil free - so maybe it was an of accumulation of gunk over time.
Next job is to replace the crankcase breather cyclone unit and associated pipes as the fabric covers were all frayed.
Going with shiny red silicone Rolling Eyes
Lubricated the 'governor' pin (don't know what its really called Embarassed ) that connects with the boost pin chamfer and her took for a spin ………
Performance seems a little better - a would describe it as 'smoother' more than anything, in the 30-50mph range - so that's good.
Even took her for a proper blast up the motorway and got upto 85 Shocked - not for long mind you as the soft top was flapping like crazy....and I got a bit scared Laughing
So yeah - all a bit better, seemingly smoother running, and quite comfortable at around 65mph Thumbs Up
Post #839046 22nd Jun 2020 10:57pm
red zepplin
Great news Frenchy a word to the wise if you replace the pipe from below the breather cyclone to the crank case ensure you use a lined silicone pipe as silicone doesn't like coming into direct contact over a long period of time with oil Thumbs Up
P.s. shiny red is a great colour I have a set
Waiting to go on the zepplin Very Happy
Simon WHAT COULD POSSIBLY GO WRONG
Post #839162 23rd Jun 2020 3:40pm
frenchy
Well there are new shiny inter cooler hoses.....
New shiny Standard Size Allisport Intercooler ( need to move the horn!!)
And just waiting to fit these Shiny Red breather pipes (not lined😬)
Post #839626 25th Jun 2020 12:18pm
red zepplin
Just keep an eye on the guy who supplied mine says fatigue would occur about 12 months under normal circumstances
Thumbs Up looks great
Post #839636 25th Jun 2020 1:14pm
frenchy
...... and fitted.
If nothing else, over the last week, removing the radiator frame and the various hoses has given me the opportunity to give some of the nooks and crannies a deep clean with some white spirit and a tooth brush!!!
Hope the new hoses last over 12 months though Shocked 2000 D2 TD5 - ahhh bless
Post #839762 25th Jun 2020 10:24pm
red zepplin
Thumbs Up Thumbs Up looks great and I now need to get mine fitted Embarassed to allay any fears of the pipes failing just drop stoney racing (looks like you got them from there) an email and ask if the cyclone to crank case is a fluro silicone hose if it is all good if not just keep an eye on it when you lift the bonnet Thumbs Up
Post #839808 26th Jun 2020 8:45am
