Home > Puma (Tdci) > Cant get MudUK reverse LED to work
jbullis
United States
I thought the first one was faulty so they sent me another. I have a LUX branded LED reverse light and it works. When I put try MudUK, there higher end one doesn't light up. Anyone else had this happen or any ideas how to make it work/https://www.mudstuff.co.uk/products/electrical/exterior-lighting/defender-95mm-nas-defender-reverse-lamp.html
Thanks
Post #837580 16th Jun 2020 5:22pm
Rashers
Have you swapped the polarity of the cables?
Post #837582 16th Jun 2020 5:27pm
jbullis
United States
I'll try popping out the pins and swap the cable to see if it works. I would hate to think two were wired wrong?
Post #837583 16th Jun 2020 5:29pm
Martin
Site Admin
Worth trying this, as your reverse light plug (on the vehicle harness) may be wired back to front. Or the socket on the lamp may be wired in the wrong pins.
Or post some pics of which wire is where on the plug and on the socket and I'll check what they should be.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #837584 16th Jun 2020 5:33pm
jbullis
United States
Thanks for the quick reply’s. I swapped the wires and it lit right up.
Post #837600 16th Jun 2020 6:27pm
Pacha
LED's are polarity sensitive. Rgds.
Chris
Post #837624 16th Jun 2020 7:48pm
discomog
Had a similar problem on some plough lights I recently bought for my tractor. Someone on the Chinese production line couldn't tell the difference between a red wire and a black wire or decided to swap them around for sheer devilment. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #837723 17th Jun 2020 7:31am
