Home > In Car Electronics > CTEK 5 or CTEK 7? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5855 |
Thanks BW, 1999 Defender TD5 110
12th Jun 2020 9:25pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1081 |
Does the 5 come with a temperature sensor? The 10 does.
12th Jun 2020 9:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
No, CTEK reckons no external temp sensor is needed on the 5. The ten is a plug-in and the charger will run without it, the 25 it's permanently attached and should be used. I guess the theory is a 5A charge rate is unlikely to overheat the battery.
The downside of the temp sensor is you can't extend the lead from the charger to the battery, or plug the charger into a prewired socket on the car, so it is in many cases a disadvantage. |
13th Jun 2020 5:55am |
„ I guess the theory is a 5A charge rate is unlikely to overheat the battery.“
Sounds plausible. I always thought (may have read in the manual?) voltage would be higher in low temperatures? As the CTEK gets warm the sensor is external I thought, but temperature near the charger should be the same as in the battery box, no? |
13th Jun 2020 6:36am |
I think the temp sensor is supposed to measure the approx battery temp, not ambient, but I'd have to check the CTEK book of words to be sure. I'm pretty certain that the 25 says the sensor must be placed on the battery.
13th Jun 2020 7:17am |
Just checked the 10's manual, but only says "adapts voltage to ambient temperature". Nothing on how it's adapted or where to place the sensor :-/
Oh, when I was at the local LR dealer the other day I spotted some CTEKs lying underneath New "Defenders". I think they were the smaller ones (the CTEKs, not the Defenders). So, should be good then |
13th Jun 2020 3:51pm |
siglo Member Since: 07 Aug 2015 Location: Kuwait Posts: 50 |
Hi Joe, I would appreciate if you can elaborate further of your experince between the Cteks and NOCOs. You see, I've been using Ctek Chargers for a very long time and last month got my first NOCO 10 amp charger (new version). I currently have a 5, 10, & 25 amp Cteks plugged to charge different vehicles. I also happen to have two Ctek chargers that went bad that I will try to have repaired (5 & 25 amp versions). It might have been operator error but I don't think I've done anything unusual. The 5 amp one went bad after I kept it connected to the battery and unplugged from the wall. The 25 stopped working after I tried using it to charge a vehicle with a dual battery setup. So I got a NOCO to try out and my first impression was the opposite of yours. The plastic of the NOCO feels much more solid in my hand and the charger seemed heavier than the equivalent Ctek. It also seems that the connectors are beefier on the NOCO (not beefier than the Ctek 25 amp though). So I guess my question is, do you have the new or old versions of the NOCO's? I think the old is grey and larger and the new ones are black and smaller. And did any of the chargers you have (Ctek or NOCO) go bad on you? I like that Ctek has more accessories, cables, connectors etc which can be useful. But after trying out the noco I'm leaning towards replacing my Ctek's which noco's if any of them stops working. |
13th Jun 2020 9:28pm |
Amazon UK are a ripoff. Ctek MXS5.0 at 85 or even 95£? You guys can order the same on the German Amazon site (amazon.de) for 61.50€ plus less than 5.00€ shipping to UK. That is the equivalent of totally about 60£ delivered. And that includes the German VAT which I think until end of this year takes care of everything, also post-Brexit now. No further UK VAT or import duties due. Worth a check I think.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
14th Jun 2020 4:18am |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
Ive got a 5 and 7. Use the 5 on my car, and the 7 is on the landie with its dual batteries.
I think the rule of thumb is the relationship between the Amp hours in the batter(ies) an the amp rating of the charger. I think unless the battery is completely flat then a ctek5 will be fine for topups and conditioning. |
15th Jun 2020 9:12am |
Presumably this would not have a UK mains plug but some strange European plug (a shaver plug sort of thing)? |
15th Jun 2020 9:59am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello excossack
CTEK 5 or 7 will be a good purchase. I went for the 5 and love it, CTEK looks to constantly review well. What really makes it a simple plug in (considering a Defenders Battery position) is Martin's 'smart plug' for either the 7 Pin 12S or 13 Pin Towing Electrics. https://www.disco3.co.uk/shop/tow-electric...c-p45.html https://www.defender2.net/forum/topic70607.html SKIP https://www.defender2.net/forum/topic83242.html |
15th Jun 2020 10:16am |
I was going to go for the 7 but out of stock/not available.
I took the plunge and ordered the 10. I shall take a look at the adapters from Martin. I have the 7s socket (no 12). ** I only have the 12N socket with the black cap. ** 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
15th Jun 2020 10:30am |
I would say luckily it has no UK plug. Speaking of something weird. But, we in Switzerland have different plugs too. Just cut the German off, and replace by a UK version you buy at your local do it yourself store. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
15th Jun 2020 11:03am |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
I have three CTEKs, a MXS 5.0, a 'Powersport' 2.3A and a 'Start/Stop' 3.8A, all the same physical size.
I've two NOKOs, a Genius G1100 1.1A and a Genius 2 2.0A. The earlier NOKO is certainly cheaper looking than the G2 and the G2 seems to have caught up with the CTEKs in terms of the quality of the casing. I'd agree that the crocodile clips on both NOKOs are better than the CTEKs, but I've had no problems with any of them. I did have a couple of other higher output first generation NOKOs which, to my irritation in hindsight, I gave away. That was before I had five boat batteries to keep charged up though. I perhaps should explain I'm lucky enough to be an Amazon 'Vine Voice', which means I get offered free samples to review (although the virus has stopped that at present), so the MXS 5.0 is the only one I've had to buy. If I ever need to buy another, I'd probably stick with the CTEKs purely through being pleased with the 5.0 over many years, but the NOKOs are still great bits of kit. All, of course, are made in China. |
15th Jun 2020 1:14pm |
