Home > Technical > Front 2" Receiver Options |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 |
Hi,
I am looking for an option to mount solidly a 2" receiver on the front of my 90 for a project. I have found a bumper from firstfour https://www.firstfour.co.uk/defender-heavy...ocket.html and a bash plate from safari Equip https://www.safari-equip.co.uk/defender-st...d-pin.html Anyone else aware of any other options? I am going to be designing a detachable rack for the front end. It will that hinge up so it sort of looks like a bull bar when not in use, then be able to fold it down flat and it will be complete with a sliding tray/ramp arrangement to enable the recovery of red deer from the hill. Idea would be to tie it in to the recovery points as well to take the torsional load off the receiver pin. Total max load will be 150kg when its loaded including the rack itself, so dynamic loading of ~300kg. trying to avoid this look... road legality not an issue Cheers Mike [/img] |
5th Jun 2020 1:23pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
https://www.ebay.co.uk/itm/124207542815 this one, complete is cheaper than bumper option Cheers
5th Jun 2020 2:12pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 406 |
Those were the only 2 that I found. I ended up with the first four bumper. Very strong and well made. I got galvanised and then painted it. Forget powder coat as the inside of the hitch soon rubs that off.
5th Jun 2020 2:29pm |
OK thanks, sort of confirms what I thought.
JST - thanks for sending the link but not quite what I am after. Regards Mike |
7th Jun 2020 11:25am |
7th Jun 2020 1:38pm |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 870 |
Watling Engineering?
I no longer trailer-sail but my truck's fitted with one of their push-bars (I never was much good at reversing a boat down a narrow slip), three receivers 'cos if the truck's offset you get more of a view of where you're going rather than just the front of the boat or caravan... Peter |
7th Jun 2020 10:12pm |
good call - £170ish from what I can see for something rated for 250kg nose weight and dual receiver locations which is what I am after....
thanks |
8th Jun 2020 6:59am |
dkmlondon Member Since: 15 Jun 2018 Location: London and Somerset Posts: 14 |
I have fitted one of these to my 110, to help with boat manoeuvres - makes things simpler!
http://www.extreme4x4.co.uk/Store/Protecti...t-receiver ******** Best Duncan 2006 110 Td5 CSW / 2001 90 Td5 ragtop lhd / 2017 Disco sport / XK120 |
1st Jul 2020 12:18am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17544 |
^^ That would appear to be the Safari Equip product (or a near exact clone).
1st Jul 2020 8:07am |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 |
^^^ Correct.
The same installed on mine, here (not the best photo) but a decent bit of kit (and bloody heavy to install!): Click image to enlarge Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
1st Jul 2020 12:14pm |
