![]() | Home > Puma (Tdci) > Spectre Arches |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
![]() Click image to enlarge Tried them on mine. Unless you go mega wide they dont look right imo. Im om 285/75 tyres with 30mm spacers. ![]() Click image to enlarge |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
agree with above. You've got to go BIG on the tyres (37+) for them to look right.
I'm on 35's and went for the terrafirma +50mm jobbies. ![]() Click image to enlarge |
Pardeep Member Since: 12 Jan 2016 Location: Birmingham Posts: 70 ![]() ![]() |
Thank you both,
I'm thinking 35" BF Goodrich KM3's and yes 50mm spacers. Camelman are you running the same set up? |
Same as 35s, 315/75/16. On a 16x10 wheel with et-32 so no wheel spacers required.
It looks great.
I’ve got some Boost wheels that I’m thinking either Matt black or gloss but these will require spacers. Hopefully once it’s all done I’ll get some pics up. |
Are they standard 16x7 boosts? They're too narrow to fit a 35inch tyre as they're 12.5 inches wide.
You'll probably need a 16x10 wheel. |
Yes standard boost alloys. No big deal if they don't fit as a friend has offered some Mach 5's which I wouldn't mind.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
265's with a 30mm spacer on std boosts will fit under a std wheel arch.
Not sure if a 285 is recommended for a boost alloy? HTH Keith |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
Many people have run 285s on Boosts for years without problems (other than negotiating tight corners of course), but you are right in that manufacturers won't recommend this size for Boosts.
Silver110 Member Since: 10 Jun 2020 Location: East Sussex Posts: 49 ![]() ![]() ![]() |
Looks great, do you have a link to your build? Or some info on mods? I’m currently looking at 33”s or 35”s would love the 35”s but unsure if to much strain in drivetrain/bearings etc. Mines purely for laning and doing some long camping trips so not “to” Fussed about the ride. ![]() Click image to enlarge |
Trendkill110 Member Since: 04 Sep 2021 Location: Yorkshire Posts: 73 ![]() ![]() ![]() |
Morning folks.
I'm on with fitting Spectre arches to my 110. I purchased them from LR parts, they seem decent quality besides the screws provided. What have folks done about the 'gap' on the front inner wing? I'm fitting 37" trepadors. TIA 👍🏻 ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
I kept the original wheel arches and basically trimmed the outer arch off with a stanley knife.
The wider arches were then fitted ![]() |
Think I'm going to sleep on this before I cut the s**t out of my truck....
Any last words of wisdom? ![]() ![]() Click image to enlarge |
