![]() | Home > Puma (Tdci) > Air con radiator fan - when should it be running? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Not a clue, but I haven't noticed mine running in 8 years of ownership of two defenders.
A/C works fine, so I haven't worried. Enough other things to keep me busy though ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4253 ![]() ![]() ![]() |
It must have some sort of temp control. Mine kicks in and out a lot in warm weather, not so much when it's cold out. 2007 110 TDCi Station Wagon XS
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
The only time I seem to notice it, or at least I assume it’s the AC fan, is if I’m operating somewhere hot, say at least high 20s low 30s and I’ve slowed down after driving at higher speed e.g coming off of the autoroute in France.
There is then a low pitched roar from the fan.. I suppose it could also be easier the viscous fan on the engine..... ![]() |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 934 ![]() ![]() ![]() |
As above, only when air temp reaches 28 degrees or above I think at least on the TD5 anyway, it's quite a roar when it does kick in! Mine came on last year when we had a few days in in 30s so it's not very often called into action in our climate in the UK.
That explains why I never hear it then. Don't think I can ever recall temperatures reaching 28 up here in Fife!
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
It actually reached 29.4C in June 2018 at the Fife weather station. Unbelievable but true
![]() Mini Countryman Cooper S Morgan Plus 8 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3393 ![]() ![]() |
I think you'll find the 'roar' from the fan when coming off the motorway is the viscous fan kicking in as the engine is hot but suddenly loses the cooling effect of the high speed air coming through. The a/c fan is much quieter. |
yorkshirelandy Member Since: 26 May 2015 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Thanks guys, I’ll see if the AC gets properly cold once I’ve changed the heater valve this week.
Fingers crossed! '09 Puma 110 CSW XS |
The roar you hear is the viscous fan which is related to the engine cooling circuit.
The A/C is the smaller electric fan in front of it. That will come on when you switch on A/C together with the interior ventilation fan which also will come on automatically then at lowest speed, even if the switch is in the off position. Both A/C fan and interior ventilation fan should remain on as long as you have not switched the A/C off again. Without both fans and the A/C compressor working, no A/C cooling at all. The only thing I don’t know is if the Puma Defender A/C system has a sensor which deactivates the entire system in cold weather when the outside ambient temp drops below a certain point. Our VW has that, its A/C won’t come on if ambient temp falls to under about 6°C. But otherwise the Puma electric A/C fan should keep working permanently when A/C is switched on. No sensors at all to regulate its function according the required interior temp, purely a manual on/off system. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks Eric.
Sounds like I've got an issue then. It was nice and warm when I tested it yesterday and the little fan never moved! I'll start simple, fuses etc. '09 Puma 110 CSW XS |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
@yorkshirelandy - I really think that you're over-thinking this - like a worried-well person!!
Always a good thought to check fuses periodically, but - does the AC work? If it isn't you'll know it - I once drove through a ford, dunked the condenser fan and blew the fuse, it was immediately obvious even in low 20's outside. The info above isn't quite right. The AC system has various functions driven from the ECU depending on a number of parameters e.g. idle jack, speed, engine temp, load: see final post here... https://www.defender2.net/forum/topic51495.html JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 251 ![]() ![]() ![]() |
I think mine goes on and off in sync with the compressor. 1953 80"
1987 mini city e 2011 90" |
@widget I think you're right haha, it's an affliction!!
I'm gonna chill (no pun intended) and wait until I have the new valve fitted before I do any more digging. It's definitely blowing colder than ambient temp so I'm happy with that. '09 Puma 110 CSW XS |
Just an update on my air con
![]() The main issue is, I assume all LR stuff to either not work or be generally crap...so I had no idea how cold the AC should have been... Got it regassed, it was 'colder' than ambient..maybe? Changed the stupid plastic heater valve that was leaking, new one leaked... Changed it again, it leaked again...decided i'll live with it for now. Checked the 20amp AC fuse, it had blown! I cant believe I never checked it ![]() Anyway, fuse changed and I now have icy cold AC...happy chappy! I have still yet to see the front AC fan running but as previously suggested there are a few parameters to meet before it kicks in. '09 Puma 110 CSW XS |
