Home > Wheels & Tyres > New Blindos arrived |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 524 |
I can’t help with the wheel carrier, but just a thought I am sure 7.50’s are supposed to be too wide for Blindo’s as they are quite a wide rim ? 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI |
23rd May 2020 3:15am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Very nice wheels indeed
23rd May 2020 5:59am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3690 |
Should be fine. You might need to adjust the stoppers that the wheel bolts against but that will be it.
23rd May 2020 6:17am |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
I’m pretty sure a 750 or 235 is probably about the minimum that can be fitted to this wheel, the military fit them with 750 tyres for their WMIK Landys |
23rd May 2020 9:43am |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 |
They look great, have lusted after a set of those for my 110.
Might be worth while they are new, clean, un-rubbered and off the vehicle to get some protection on them, some wheeel wax or a ceramic coating to keep them looking pristine for longer and easier to clean when they get covered in brake dust, road slime and mud? I've played with this coating : https://www.carboncollective.com/product/platinum-wheels/ on a set of Boost alloys that I'm about to get rubbered up and fitted. it has made a diffrence to how the rims look and feel, gloss looks better, and when sprayed with water seems to bead up and roll off better. does require some prep and paitence to apply but worth it for a big investment like wheels that you don't change regularly. WAXISDEAD will give you a 10% discount once back in stock Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
23rd May 2020 9:54am |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 |
Zaid,
Your photos are awesome. Thanks for including your link (www.defencephotos.com). Andy |
23rd May 2020 10:28am |
The Zee.
Thanks for that, I’ll certainly look into getting them coated before fitting, cleaning between those little spokes won’t be much fun so anything that helps keep them clean will be ideal. |
23rd May 2020 10:40am |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 |
If you do decide to get a Mantec carrier be careful as the back plate can rust
Mine rusted which then rusted the back door - unseen until it was removed Now replaced with a stainless carrier Click image to enlarge |
23rd May 2020 10:50am |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
Mantec carriers seem to have a fairly poor powder coat and are not galvanised pre coating. Mine has blown after 3 years. That said it is at the affordable end of the cost spectrum so you pays your money etc etc...
23rd May 2020 12:50pm |
Regarding using 7.50 XZLs on the Blindos, I suspect they are not recommended as the tyres are too narrow. That said, I would personally be inclined to get one fitted and see what it looks like - I know it sounds a bit arbitrary but it's what I'd do. I think it'll be fairly obvious if the tyre is too stretched. WMIKs, although using XZLs and Blindos only seem to use the 235/85 version which is quite a different tread pattern than the 7.50 version and looks significantly wider. There was a lightly used set in the for sale section recently.
23rd May 2020 12:55pm |
Hmm Got me wondering now about the suitability of using my existing 750s. Does anyone here have experience of fitting them to Blindos, or better still pictures? I really don’t want to have to go down the road of new tyres as well I had to disembowel the piggy bank for the wheels.
23rd May 2020 2:16pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 |
I've only ever run 255/85 BFG KM2 and KM3 on my Blindos, and I do feel 7.50s would be a bit skinny. You don't want the hot hatch "slammed and rimmed" look.
23rd May 2020 2:32pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Think the XZLs Thon is referring to are mine... PM me if you're interested as they're still for sale at the moment, all have around 12mm of tread so barely worn - I only used them in the winter on the shoot.
Click image to enlarge Click image to enlarge |
23rd May 2020 2:43pm |
Just bear in mind that HD (Wolf) rims are 6.5 inches wide and are absolutely fine with 7.50 XZLs so the stretch to 7 inch wide rims is only 6mm more each side. Not a fat hairy lot really. I'd also listen to the advice of the tyre fitting shop you go to because I am sure they've been asked to do way more extreme stretches by yoofs wanting that specific look.
23rd May 2020 4:31pm |
