Home > Tdi > Coolant y piece
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
Coolant y piece
Hi guy's
A quick question I am just about to replace the rubber coolant hoses on the red zepplin with silicone and was wondering if anyone has done this and replaced the y peice ejector that comes off the expansion tank with just a simple t piece or if I do need to reuse that for some strange 300tdi coolant reason Rolling Eyes
T.I.A.
simon WHAT COULD POSSIBLY GO WRONG
My sky lantern petition
http://chng.it/HJXmZC47
Post #831416 16th May 2020 4:40pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Assuming the picture below is what you are referring to
It's a none return value so yes you should re use it.
Post #831420 16th May 2020 5:03pm
red zepplin
Great thanks nidge yes that is the 1 Bow down WHAT COULD POSSIBLY GO WRONG
Post #831436 16th May 2020 5:58pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Here in South Africa it's common to replace it with a simple brass one from a gas equipment supplier called Cadac.
They tend get blocked and cause problems.
Post #831561 17th May 2020 11:56am
red zepplin
Thanks jfh do you guys replace with a valve or just a t peice? I am looking to both simplify and increase reliability Laughing WHAT COULD POSSIBLY GO WRONG
Post #831591 17th May 2020 3:24pm
jfh
Just this.
Post #831597 17th May 2020 3:39pm
red zepplin
Thumbs Up thanks WHAT COULD POSSIBLY GO WRONG
Post #831599 17th May 2020 3:43pm
