Home > Technical > Damp around battery terminals
jb71
Hi All. Apologies if this is a novice question... I've gone to plug in a CTEK battery conditioner into my Defender. Around both battery terminals it looks like there's moisture, could the battery be leaking or could there be a simple explanation? There's no evidence of corrosion to the terminals and the damp area only appears localised around the terminal. Any ideas? Can take a pic if needed...
Thanks
Jon
Post #830923 13th May 2020 5:54pm
jst
Unlikely to be a problem, possibly grease residue? Clean off and apply vaseline. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830945 13th May 2020 7:01pm
Dielectric grease probably. Typically put on during servicing. It's there for good reason. Thumbs Up KEEP CALM AND Drill ON
Post #830964 13th May 2020 8:08pm
jb71
Thank you guys. Nothing to be concerned about then. Phew. Thumbs Up
Post #830968 13th May 2020 8:45pm
