Home > Land Rover Customer Relations > Rusty windscreen blocks
BarryT
Wales 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi, I have a corrosion problem on my 2015 Defender on both windscreen blocks and surrounding area. My Dealer refused to take it up by way of the 6yr anti corrosion warranty when I pointed it out during the service last year. Is there anything you can do to help get it sorted. It's only done 10k miles and has been kept indoors since new, it's a shame as it spoils the look of an otherwise rust free vehicle.
Post #830893 13th May 2020 2:24pm
camelman
You can waste your breath arguing with them or you can buy a new set for £40.
I did the latter at 3 years old as its not worth the hassle of trips back and forward to the dealer....
https://rimmerbros.com/Item--i-MUC7911--Se...gLqBfD_BwE
Post #830895 13th May 2020 2:41pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I have some corrosion appearing on one of mine.
I was planning to take it off, sand it down, etch prime, paint & lacqueur it.
Any particular advantage in buying replacements, rather than fixing up what you had?
Post #830897 13th May 2020 2:57pm
UtilityTruck
Dealer response on this issue is laughably random.
For example I had the windscreen surround and blocks painted at 3years by the dealer. They didn’t do a great job and they’re going again at 6years old. I’ll be paying for a better body shop to do it this time. 2014 Keswick Utility 2.2
Post #830926 13th May 2020 6:04pm
Rashers
It took my dealer over 2 years to do anything with mine.
I think what they did was wait till the end of the warranty period, then repair everything in one go rather than numerous trips back and forth to the bodyshop.
Post #830958 13th May 2020 7:41pm
JPE
I had my windscreen frame replaced by the dealer just before the 6 years were up. The vehicle was new to me & I wanted to get it sorted before the time was up. They didn't do a bad job, except around a year later the blocks are now going. I've not got to those yet as I'm in the middle of sorting out C-pillar corrosion & trying to make good the mess I made drilling off the ladder which had corroded solid to the rear panel. Blocks will have to wait a couple of weeks... Smile
Post #830977 13th May 2020 9:38pm
BarryT
Thanks for the comments guys, I would not bother with the dealer if it were only the blocks as I would remove and do them myself but there is slight corrosion on the panel around the block and I'm not confident that I could do a good enough job on that. I will try again as soon as the dealer is open for business.
Post #831267 15th May 2020 6:04pm
RDR
The way dealers handle corrosion and damage due to the elements seems to be extremely random. Had 2 D4s where the front scuttle panels faded in sunlight first one replaced no bother second one refused as it was within acceptable parameters even though it was worse than the first!
Had a total of 5 rear ladders replaced on the Discos for rusting, the last d4 had 3 ladders in 4 years and on the last occasion the replacement that turned up at the dealers was already rusting on the welds! They agreed to send to a local firm and have it stripped and plastic coated. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D5 MY19 HSE - Now Sold
D4 MY16 HSE Luxury - Now Sold
D4 MY12 HSE - Gone
D3 MY06 S - Gone but not forgotten
Post #831362 16th May 2020 8:33am
BarryT
Perhaps Supacat can give me some information on how to get the corrosion work done on the bodywork around the window blocks, my request has now been made twice to my dealer, at first it was dismissed immediately but on this second attempt and as it has got worse it's still being considered by my dealer, they say they are waiting to hear from LR, what can I do,
Regards,
BarryT
Post #891326 14th Mar 2021 12:25pm
BarryT
I'm glad to report that all the corrossion work has been done. All sorted by Conwy Landrover under the corrossion warranty. Top dealership and a big thanks from me once again for excellent service asusual.
Barryt
Post #910074 29th Jun 2021 10:18pm
