![]() | Home > Tdi > 300 tdi fuel warning lamp |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 ![]() ![]() |
Hi chaps
The zepplin is a 1998 farmer spec 300 tdi, the low fuel warning light has never worked on this car I am just wondering should it or was it some sort of "optional extra" fuel gauge works fine and there is a bulb in the lamp holder on the warning light cluster TIA Simon WHAT COULD POSSIBLY GO WRONG My sky lantern petition http://chng.it/HJXmZC47 |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Try a different bulb first, I have the same model and fuel warning light works OK. Then have a look at the wiring at the tank end. Jeff
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 ![]() ![]() ![]() |
Ha ha! I didn't even know it had a fuel warning light.
![]() Thanks for the advice. ![]() ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Yes, for some reason LR deleted the low fuel lamp wiring on some Tdis
Thanks guys I will look at the tank sender end as I did replace all my dash lights with led lights (it didn't work before either) WHAT COULD POSSIBLY GO WRONG
I did that and have run out twice ![]() My sky lantern petition http://chng.it/HJXmZC47 |
Dang! Back to gambling then. ![]() |
