Home > Technical > Belt squeak (2.2 TDCi with a/c)
Rutter
United Kingdom 2014 Defender 90 Puma 2.2 SW Rioja Red
Just thought I'd share an odd solve - for last few weeks I was hearing a short but loud squeak from the drive belt on cold starts. Convinced I needed to change the belt or the tensioner I embarked on the process - not easy to access so removed fan. Belt off, cleaned pulleys and put back - still there. It turned out that the belt had skipped one ridge over the little 'hidden' idler pulley - when correctly set no noise whatsoever.
Post #830442 11th May 2020 9:57am
