Home > Maintenance & Modifications > 3.9 exhaust on a 3.5 - manifolds and system
Ranger 6
United Kingdom 1988 Defender 90 V8 Petrol CSW Rimini Red
Well the collection of parts has nearly come to an end. I started with manifolds (thanks Mo) and worked back from there.
What started with a thought of a quick change turned into a longer process as I hadn't researched properly and found I needed a D1 crossmember. That was the final part and joins the RRC downpipes and Y piece and the TD5 system.
Now all the bits are sitting in a pile......
It's where it all becomes a bit real. Work will start soon, but I'm struggling to find the right clamps for the Y-Pipe. I'm getting the gaskets ERR6733 and ETC4524.
The other bits I'm struggling with are some decent brass (or high temp) nuts to fit the manifold studs.
Does anyone have some specs/links for these bits please? 90 V8 CSW - 1988
Post #830109 9th May 2020 4:41pm
Rimmers do a stud and nut kit Thumbs Up Thumbs Up
Post #830110 9th May 2020 4:51pm
Ranger 6
Thanks - will have a look. Don’t want the studs at this point. 90 V8 CSW - 1988
Post #830118 9th May 2020 5:41pm
Ranger 6
So - from a bit of research here's a list so far.....
Manifold to head fixings:
Manifold bolts - SH506101L
Washers - 3036L
Locking plates - ERC7321
Manifold to downpipe fixing:
Nut - GHF252 (not sure if it should be LR019197P)
Washer - WP105
Exhaust clamp x 2 - GEX9008
Exhaust bolt x 2 - BH108101
Nut x 2 - GHF252 90 V8 CSW - 1988
Post #830423 11th May 2020 9:15am
Romadog
Olive required between y section and silencer?
Also bracket Ray to support rear of y section by gbox mounting.
Have you modified D1 xmember yet??
Have you the Td5 bracket for a frame xmember?
Post #830464 11th May 2020 2:27pm
Ranger 6
Thanks for that - I'll add the olive to the list and the rear hanger is another on the radar, just haven't found the right part number.
What are the mods required to the cross member? 90 V8 CSW - 1988
Post #830555 11th May 2020 10:22pm
Romadog
Defender chassis is deeper than Disco.
Fit xmember in chassis on top holes.
You will see that bottom holes don't line up.
Weld strip of metal to xmember both sides, squaring it up as one corner is chopped off.
Mark holes and drill them out and paint Thumbs Up
Post #830753 12th May 2020 7:56pm
Ranger 6
Perfect - thanks Thumbs Up 90 V8 CSW - 1988
Post #830839 13th May 2020 10:43am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
ESR 3294 is the exhaust bracket - std for Td5 and 300tdi.
Just got a few photos of the same conversion on mine, I reused the downpipes of my D1 V8 and had flexi-joints welded in to replace the cats. Exhaust from Y piece back is Td5/TDci.
Gearbox crossmember is D1 extended, and I've added pics of the exhaust bracketry if that helps.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #830864 13th May 2020 1:01pm
Ranger 6
That's excellent - very useful, thank you.
Any chance you could do a couple more of the crossmember and where it bolts in at the bottom. 90 V8 CSW - 1988
Post #830918 13th May 2020 6:19pm
Lodelaner
Tricky to photograph!
 JB
Post #830942 13th May 2020 7:49pm
Ranger 6
No, that's perfect - I know exactly what's needed to modify Thumbs Up
Many thanks 90 V8 CSW - 1988
Post #831040 14th May 2020 1:38pm
Ranger 6
After some time it's an update.....
It's all on - the last piece is going to be the hanger for the middle box which is yet to go on.
There was a bit of fettling to be done to get it to fit properly.
The final piece has been to fit some new needles so the engine breathes properly. I chose BBW as the standard BGC were OK, just felt a bit weedy and low rev response was suffering. 90 V8 CSW - 1988
Post #889505 6th Mar 2021 7:47pm
