Home > Series Land Rovers > Help Identifying a Land Rover
Mumpa
Canada 2004 Defender 90 2.5 TD XS CSW Keswick Green
Good Evening from Sunny Alberta,
I was wondering if any of you fine folk could assist me in identifying what model of Land Rover this is?
Its for sale here in Canada, and from what I can tell, hasn't moved very much in quite a while
The seller has stated its a 1952, but to me it looks more like a Series 2 (which I think as from 58 onwards??)
I've asked for more info, and can see me making a trip to take a look sometime next week
Thank you
Martin
Post #830002 9th May 2020 3:56am
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Definitely a series 2, Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #830003 9th May 2020 4:56am
Yes, definitely a Series II but difficult to say much more without more details.
The hole in the wing suggests a Series III style heater but it could just be a replacement wing as much as something more exotic. Darren
Post #830012 9th May 2020 7:17am
familymad
I can’t see close enough the bulkhead to determine S2 or S2a. Have you any shots that could be zoomed in? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #830020 9th May 2020 8:04am
I think it is a (fairly) early IIA, and I also think that the owner has got the wrong decade, I reckon it's a '62. It has also "evolved" over the years to gain some newer features, such as the SIII heater orifice.
Post #830026 9th May 2020 8:22am
Defender SVX
I thought deep sills and barn type door hinges were a series II thing? Formerly mao99999
55 86" SERIES 1
Post #830028 9th May 2020 8:27am
An early IIA is very hard to tell from a late II. IIRC the IIA appeared late in '61, possibly for the '62 model year, and the owner's 1952 comment (which is clearly wrong) makes me think IIA.
I also think that a II would have the early square style vanity panel between nos 1 and 2 cross-members, this appears to have the later rounded type, which again makes me think IIA, but it is a part which could easily have been "updated".
Those door hinges lasted quite well into IIA production, I believe, and initially gained provision for door mirrors to be fitted to the top hinge. I think that the smooth type only arrived with the SIII or thereabouts.
I used to have a 1961 Series II, which had the square vanity panel, also the front wings left the factor with sidelights only, so no pressing for the indicators. I can't quite make out if the front wings on this one have the dished pressing for both lights, or just for the sidelights, which would indicate no indicators from new. I don't think that any IIA vehicles left the factory without indicators, but I may be wrong. Curiously the rear of my '61 had the galv cappings with provision for two set os lights (so indicators as well) but left the factory with the rear tub un-drilled for the indicators (you could see that the indicators holes had been drilled in the tub after the cappings were fitted).
There are plenty of others here who know far more than I do about the II and IIA, so further information may well come forth.
Post #830056 9th May 2020 10:32am
For most export markets, Series II's had indicators fitted as standard. It was really only the UK where they were an extra. Darren
Post #830136 9th May 2020 6:30pm
Slideywindows
Post #830161 9th May 2020 8:28pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
The problem with old Land Rovers is that over the years many parts could have been changed for newer or sometimes older parts, the classic “bitsa” vehicle. Therefore it’s very hard to determine the true age of a particular vehicle from a few photographs. Suffice to say it’s not a 1952 Series One.
Post #830220 10th May 2020 9:55am
