Home > Puma (Tdci) > How do I stop this bolt falling out ?
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I must have lost this bolt three times. Why does it keep falling out and how do I stop it ?
Post #829618 7th May 2020 8:21am
bear100
Have you used threadlock? i use the Rocol blue.
There are different strengths and will certainly help you, Cheap enough and stocked in Halfrauds]
Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #829622 7th May 2020 8:33am
You probably won't stop it falling out. The problem is that it screws into a blind hole tapped into the cast-iron exhaust manifold, which is (a) fragile and (b) subject to a huge range of temperatures. Given the different coefficients of thermal expansion between the CI manifold and the steel screw, it is almost inevitable that it will keep coming loose. Eventually you will find that repeated tightening and the general unsuitability of CI to hold a thread means that the thread in the manifold will fail, and then you either need a new manifold (the dealer solution) or you simply throw the setscrew away and bend the parts slightly to stop the rattle (the pragmatic approach).
I have been running without this screw for around 150k miles now, the intermittent rattle is the only downside.
I did investigate fitting a threaded insert (Helicoil or Timesert) to the manifold but the hole is ridiculously shallow and it really cannot be done without drilling through into an exhaust passage, which is probably not a good idea.
I doubt that there is a threadlocking compound that will withstand the heat of an exhaust manifold, although I would be happy to be proved wrong on this.
I have toyed with the idea of making a bracket that attaches somewhere else to support this (for example, the bolts/studs that hold the manifold to the head) but I've never actually got around to trying, it has never reached the top of the list of priorities.
It will be interesting to see if anyone else has found a solution to this idiotic piece of sloppy design.
Post #829623 7th May 2020 8:56am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
You could try a very slightly longer bolt with a spring washer under the head.
Post #829636 7th May 2020 9:36am
Avelingporter
Use graphite powder mixed with a small amount of engine oil to form a paste. Use this as a thread lock. It’s what we use on steam engines. The oil burns off and the graphite sets hard.
Post #829656 7th May 2020 12:17pm
CharlieDonuts
Thank you for the explanation Blackwolf and other forum members for their the interesting ideas. I was particularly taken by the Isambard Kingdom Brunel 'steam' solution but was a bit worried that I might not ever get the bolt out again. There is a gasket down there that I have had to change, that I need to change again now and no doubt will need to change in the future. I have tried the springy washer before and it fell out. So I am thinking that I might try this.
https://tdsna.henkel.com/americas/na/adhes...422-EN.pdf
If the High Temperature Loctite doesn't do it I'll give Isambard a whirl and if that doesn't work I'll go back to not caring Cool
Post #829931 8th May 2020 5:28pm
Unfortunately I can't follow that link (it requires a login), so can you say how high a temperature the high temperature Loctite is good to?
Working hard the exhaust manifold could exceed 400 degrees Celsius and it would be pretty impressive threadlock to cope with this.
Post #829939 8th May 2020 5:56pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Like it Thumbs Up Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #829943 8th May 2020 6:17pm
ickle
Drill the head crossways and wire it aviation style?
Keith
Post #829946 8th May 2020 6:28pm
CharlieDonuts
Loctite® 2422™ Ultra High Temperature Threadlocker Blue
https://www.henkel-adhesives.com/kr/en/pro..._2422.html
Here is the URL there is another link to a PDF
They have only tested it up to 350 C
Dunno what do think
Steam Engine Method ?
Post #829955 8th May 2020 7:06pm
CharlieDonuts
Maybe this ? Its not to hard to get to this bolt so I ought to be able to get it ought again with a breaker bar.
Post #830038 9th May 2020 9:23am
That should certainly provide the heat performance you need, impressive!
Post #830054 9th May 2020 10:23am
bear100
Thread lock is the way! 2016 Range Rover Autobiography 4.4 TDV8
Post #830123 9th May 2020 5:05pm
