![]() | Home > Puma (Tdci) > Chasing a leak in the footwell |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Hi MussEd
By every single entry I mean if somethings going through the bulkhead from the engine compartment, wires, cables etc & reasonable access can be gained, I usually put a thin layer of gutter repair around the hole, bracket, grommet or whatever & the stuff is fairly easily removed & cleaned off at a later date. This is the type of stuff: https://www.sealantsandtoolsdirect.co.uk/s...23556.html I've also had fairly good results with Tiger Seal on the windscreen/bulkhead seal, its a bit more sticky than gutter repair but last longer: https://www.eurocarparts.com/p/u-pol-tiger...UPL.TIG_NB Arbormast for the windscreen rubber: https://www.dortechdirect.co.uk/arbomast-a...reens.html I also bung ACF50 waterproof grease in the window block holes & also have found these gaskets from Powerful UK (brilliant company) to be the best fit: https://www.powerfuluk.com/vehicles/land-r...t-4pc.html & to think, we love these vehicles!!!! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 ![]() ![]() ![]() |
Thanks Fatcog - that’s my weekend activity now sorted!
You're most welcome! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
That notch is normal(i contacted landrover) for defenders window seals (my guess its a lr off the peg cheap seal where the cut (not full thickness)into the seal allows it to be used on curves) ill find a picture if i can!use captain trolleys and seal with silicone or grease! see here.. https://www.defender2.net/forum/topic38849-15.html |
Johan H Member Since: 12 Oct 2017 Location: Helsingfors Posts: 36 ![]() ![]() |
I have had exactly the same leak on my -08 Puma. Mended all above mentioned things which made the leak smaller but intermittently it would still appear. In the end I noticed it would leak most when not parked level
I then Installed a snow cowl, and that solved the leak completely. There were a lot of old crap & mud under the air intake on the fender, which made the water leak out valve not work properly. |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 216 ![]() ![]() |
Mine are all leaking like the proverbial sieve....
Is there a difference in quality of windscreen seals? I looked online and see Bearmach etc. Any recommendations before I order a couple to try. Thank you ![]() |
Griff90bowler Member Since: 24 Feb 2021 Location: Cowbridge Posts: 134 ![]() ![]() |
I found my rear washer pipe rubbed through on the dash
