![]() | Home > Technical > Heated seat problem |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8182 ![]() ![]() ![]() |
Any thoughts please? Cheers
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Try running a temporary power supply from the battery to the seat elements. This will establish whether they are working or not.
From there you can work back through the seat wiring and then the loom. |
Cheers, spare seat that works off its wiring doesn't work on drivers side so pretty confident it's the wiring not the elements. Cheers
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
This is the 2.4 Puma heated seat diagram.
The (shared) ground point C0809 is on the engine bay side of the bulkhead, behind the coolant header tank, should be on the stud next to the one with the big multi-way ground header attached. C1401/C1403 are the sockets mounted on the seat box. Check the socket for continuity to a known good body/chassis ground on the black wire. Check for 12V on the blue/pink when the ignition is on and the switch is down. https://www.defender2.net/gallery/albums/u...EATING.pdf ![]() ![]() |
thank you martin for suggestions, will get on to it hopefully tomorrow Cheers
resolved, the heated element in the seat base was broken and not allowing complete circuit. have now replaced the element. So an 11 Plate with two new elements needed (back and base) of drivers seat - they dont seem to have lasted long! Cheers
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 541 ![]() ![]() |
Previous owner obese?
No idea. Cheers
