Home > Maintenance & Modifications > Can you identify this hose
ChrisDefender
Hi,
2011 2.4
Is anybody able to identify this engine hose for me please? Bow down
OK, after more searching I think it might be a Radiator Hose Upper but not sure. Can anyone say if this is correct:
JHB501780 - Defender 2.4 Coolant Hose - Heater Inlet Hose
If so, I have a of question:
If I replace it, is it possible to get one of the large rubber spacers to fit this hose, marked with an * on the image as it is rubbing on the Screen Wash reservoir and looks like it could go through (hence the temporary silicone tape).
Any help appreciated,
Cheers all.
Post #829215 4th May 2020 1:43pm
jst
rubbing on the power steering res you mean, or thats where the tape is anyway
try self amalgamating tape over the hose thats damaged, then tie wrap and old bike inner tube around it for further protection. the pipes have quite a thick wall, the cords are halfway so if you can see cords, which islikely, then its not going to go bang anytime soon (if at all) Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829233 4th May 2020 4:23pm
ChrisDefender
HI James,
Sorry, yes it's rubbing on the power steering reservior, just got two little grooves in it.
I have wrapped it in the self sealing silicone tape, so I will take your advice and get an inner tube on there too!
Excellent, thank you!
Post #829237 4th May 2020 4:33pm
I usually keep a few old hoses around so that if necessary I can cut a piece off one and use it to sleeve hoses, pipes, and cables etc., if I am worried about chafing.
Post #829247 4th May 2020 5:30pm
ChrisDefender
Hi Blackwolf,
Yep, good idea, I will start a collection!
Post #829340 5th May 2020 8:54am
