Home > Technical > Anybody recognise this rubber part
beardiedog
England 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
HI I've been doing a lot of lockdown tasks on the Defender and found this on the driveway. I'm not even sure it came off the car. I thought it was for the radiator at first but just been out the check and they are both present and the collars are actually thicker. Does anybody recogise a rubber bit like this? 2003 TD5
Post #829184 4th May 2020 10:20am
Grouse
It looks like the rubber mounting between a rear bench seat and the tub capping. The seat back of the bench is bolted to the capping and the bolt passes through that rubber. It does on mine and they are Factory fitted. 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #829218 4th May 2020 2:28pm
beardiedog
Goo call I took the seats out a while ago so maybe it came out as part of that little job https://www.lrworkshop.com/diagrams/land-r...ench_53668
Post #829220 4th May 2020 2:36pm
Grouse
That’s the 1 - item 14 on the diagram Thumbs Up 2017 Range Rover L405 Vogue SE V8 Diesel #16
Post #829251 4th May 2020 5:51pm
Co1
Hell of a spot! Well done that man!
Post #829257 4th May 2020 6:18pm
