![]() | Home > Technical > Fitting the Ashcroft CV to the halfshaft |
Leave the collar where it is. To insert the shaft you need to squeeze the spring clip a little with a pair of needle nose pliers or similar. The shaft should just push in once you have done that.
Dont be tempted to reach for the hammer, you will end up damaging the clip or the lead-in on the splines. Once the clip is inside the splines of the CV, it should freely push in right upto the spacer. The spring clip just opens up when it gets to the other side of the CV. Hard to explain but hopefully that helps? Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
That helps enormously, thanks Steve. I thought there must be a cheeky trick to it - squeeze the circlip first, why didn't I think of that! 2005 Td5 90 XS
1989 V8 110 CSW |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8181 ![]() ![]() ![]() |
put the cv in a vice vertically.
use grease to centrally locate the sprung clip line up splines push in gently until clip contacts the CV cup, ensure clips is still central gentle tap copper faced mallet on end of shaft CV and shaft joined. well thats how i have done it for the last 20 years never had an issue. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 29th Apr 2020 8:20am. Edited 1 time in total |
I'll be doing it first thing in the morning, thanks for the additional information James. 2005 Td5 90 XS
1989 V8 110 CSW |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2196 ![]() ![]() |
With standard shasfts and CVs did the ole drop fit.
Seat the shaft in the CV enough to hold it and drop it from about half a ft. Works. ![]() Click image to enlarge Sadly twice. ![]() ![]() Ashcroft ones MUCH harder...... Instagram @defender_ventures Empire Tuning - Agent |
just fitting Ashcroft ones to mine, due to me tomorrow
![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
