![]() | Home > Australia & New Zealand > Sans/Snow Anchors |
BG1 Member Since: 15 Dec 2008 Location: Midlands Posts: 6 ![]() ![]() |
Sand / Snow Anchors Hi, I'm researching the Sand and Snow anchors that 4X4 vehicles use in very extreme conditions IE:- Snow {the loose powder Snow) that does not form a snow ball because it to cold and dry. Sand, the very loose wind blown desert sand. I have looked at the "plough style" and peg Style and I am looking for people who have had the successes and the failures with this style of equipment, but do they really work in Snow and Sand with a fully laden expedition on the end of the winch rope. I welcome all sensible input and comments if you have had experience of this type of equipment Regards BG1 |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 ![]() ![]() ![]() |
I've not seen any one use a sand anchor here personally. Normally we travel in pairs or more and use a snatch strap and another car. I've have heard stories where they have pulled out of soft sand and in that instance the person used the burried spare wheel method. Like all things, I suppose they have their limits. They probably work very well in 95% of recoveries, but like all these things, you should always have a back up plan.
Ray Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
I have gone through a number of forums looking for answers to which land anchors works in Sand and Snow. Some poeple have used a boat anchor called a Danforth, and it said it works well in Sand, it comes in various sizes and is cheaper than some other equipment for 4x4. But I would like to know does it work in Snow?
Regards BG1 |
portal pat Member Since: 05 Jan 2015 Location: South. Very south. Posts: 36 ![]() ![]() ![]() |
www.lan-cor.com End of story. Nothing suggests poor workmanship like wrinkles in the duct tape.
We successfully used an X Eng ground anchor at Marquenterre one year to winch a CJ jeep up a long, steep, sandy climb
