Home > Puma (Tdci) > Body Alignment
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Body Alignment
My body gaps are decent expect for this one side. What is the easiest way to realign? Take interior trim off and back the really tight side out ?
Post #78229 28th Jun 2011 5:06pm
Happyoldgit
Yeah, remove the rim to access the hardtop mounts, slacken them off and nudge the panel over, you will probably have to take the weight of the back door or make sure it's shut while you are doing it. Steve.
http://forums.lr4x4.com
Post #78255 28th Jun 2011 6:24pm
defender75
So loosen the bolt and push up on the front?
Post #78269 28th Jun 2011 8:13pm
Happyoldgit
Ah, I thought you were bringing the back inline but the procedure is basically the same for the front - once you've got the trim away it will be obvious what bolts you will need to loosen as there's not a lot holding the sides to the tub. Steve.
Post #78274 28th Jun 2011 8:18pm
defender75
Thanks
I figured I would back the front bolt out a bit and tighten the back one. Hoping not to break any plastic when removing the inside trim.
Post #78285 28th Jun 2011 9:20pm
mse
Im doing this from memory and not from a puma, but i doubt there are differences
4 bolts in each lower corner of the sides with some around the door.
Loads across the windscreen to roof and the sides to roof - i recall there are an extra couple on the sides at the rear door entry
To be honest - i wouldnt bother and just leave it.
There are seals at the top and bottom of the side (so side base to tub and to roof) Mike
Post #78292 28th Jun 2011 9:43pm
Happyoldgit
defender75 wrote:
Thanks
Yep, loosening the side panel front bolt and the mid angle bracket should enable you to nudge or pull the front bottom corner in a bit. Don't shove too hard as you run the risk of dents - you might find a bit of lift to the gutter at the rear of the door aperture will help but it's a case of suck it and see.
The trim removal is more time consuming than difficult but it doesn't take that long, it's your choice as to whether the effort is worth it Wink You might find you need to replace one or two of the large grey firtree fasteners - it just depends how carefully you get them out. Steve.
Post #78298 28th Jun 2011 10:10pm
defender75
It is low on the list of things I would like to do but still on my mind. Its the only gap that is terrible so I figured if it was easy I would do it. I figured take inside trim off. Loosen one bolt and tighten the other and I would be done but I am sure it won't be that easy.
Post #78302 28th Jun 2011 10:46pm
defender75
I guess so we are all clear. The side panel of the truck seems to have a smaller gap in the front and it gets bigger as you go back on the truck. That is what I am trying to fix.
Post #78304 28th Jun 2011 10:49pm
Zagato
It looks as though the seal has slipped back or is completely crushed at the front end - you may need a new one but it should bounce back again once the bolts have been loosened. Certainly worth having a go at sorting. Nothing ventured ......... Thumbs Up
Post #78312 29th Jun 2011 6:51am
Happyoldgit
The lighter colour of your vehicle is probably making it more noticeable. Steve.
Post #78321 29th Jun 2011 8:31am
Grockle
be careful not to damage the gasket/seal or it'll leak water in between the top and the tub Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #78334 29th Jun 2011 10:17am
DefenderOfTheEarth
I've got a bit of a crease down the nearside rear panel (just to the rear of the top of the wheelarch) about a foot long.
At first I thought it was just normal (it runs along a row of rivets) but now not so sure. Of course although under warranty, I have a feeling a query to the dealer would get laughed at. Dammit. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #78335 29th Jun 2011 10:42am
