Home > Technical > Alarm and indicators when locking/unlocking
Page 2 of 2 <12
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
I don't have access to a Nanacon, but I do have a multimeter. I'll have another bash at it tomorrow. Thanks guys! Smile
Post #827239 23rd Apr 2020 4:29pm
dgardel
Italy
Re: Alarm and indicators when locking/unlocking
SteveK wrote:
I have removed the dash clocks and fitted a Raptor binnacle to replace the cracked LR one. Everything works ok since replacing the fuse for the heater fan, except the indicators no longer flash when I lock/unlock the car.
I also recently noticed that when I tried locking the vehicle with the drivers door open (unknown to me at the time) there were no warning beeps from the horn.
When locking/unlocking I can hear the relay clicking!
BTW vehicle is a TD5 110 2002
Any ideas anyone?
Thanks
Alarm Remote with low battery (as wrote on the User manual) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #827358 24th Apr 2020 11:52am
SteveK
I have already tried a new battery in the remote.
Post #827381 24th Apr 2020 1:26pm
PCM
Check to see if you have the overlay kit fitted. macfrank gave me some info on it. This was what caused mine to display the same issues as yours. Overlay kit was installed badly and had corroded at the joins.
https://www.defender2.net/forum/topic35353.html
Post #827389 24th Apr 2020 2:27pm
Yellow110
I had this same issue and it drove me mad trying to solve it (but I did in the end). Having the indicators flash when arming/disarming is actually a behaviour that can be toggled on or off just by multiple presses of the key fob when the drivers door is open. My ex used to accidentally do it all the time and I couldn’t work out why the indicators never flashed only after she had been driving it. From memory I think you have to have the door open and press the unlock button twice. The indicators will then do some sort of long flash to confirm the mode has been changed. Hope this helps.
Post #827528 25th Apr 2020 8:03am
SteveK
Not a lot of time to investigate further today as I had to appease SWMBO and do some gardening! Wink
However, I did notice something else when I finally got a chance to look at the Defender: with the ignition on there is a steady ticking noise at the nearside front - sounds like it could be from behind the headlight.
It could be related.
Post #827640 25th Apr 2020 5:28pm
SteveK
I've tested fuses and connections.
Without access to a Nanocom or other fault code reader, I can only think that the AS10 is faulty or needs reprogramming.
Is it possible the AS10 lost its settings whilst the dash was out?
Post #828923 2nd May 2020 5:03pm
Page 2 of 2 <12
