![]() | Home > Off Topic > Long reach hedge trimmers - anyone recommend a good one? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
Xp chainsaws you want go wrong, personally I have stayed away from the autotune like the 560. Running 346xp, 365, 576xp, 395xp, covers pretty much all eventualities for my uses. On the additive front, just run them dry before the winter. Whats not in there any cause any harm. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 ![]() ![]() |
Thanks guys, plenty to go on there.
As always, just need to find the justifiable price point! It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Having had a chance this weekend to test the Aldi one, I was pretty impressed. It's easy to start/handle, comes with comprehensive instructions and the build quality isn't bad although if you compare it to Stihl or Husky the difference is evident. Our hedge is roughly 9 feet deep in places and only accessible from one side so the hedge cutter was the main reason for purchasing it.
It comes with an additional pole extension which it states is for the chainsaw attachment only but it works with the hedge cutter also and measures 2.6 metres from the throttle to the end of the hedgecutting attachment which is longer than a lot of alternatives. Needless to say using it with the extension and holding it horizontal to do the top of the hedge is knackering after a while! 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Do yourself a favour and reduce it's depth. What type of hedge is it? WARNING.
This post may contain sarcasm. Last edited by Zed on 21st Apr 2020 12:30pm. Edited 1 time in total |
Mostly hawthorn but I don't think it had been cut for a few years and it's well established. It will get cut and laid next year which will reduce the depth and claw back a few feet of garden at the same time, missed the window for that this year but at least we now have a view across the fields
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
I guessed it would be a thorny variety! They're usually neglected for obvious reasons. Sounds like you have a plan though. Sorting the depth will make a big difference. WARNING.
This post may contain sarcasm. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
If you or anyone wants to buy a petrol powered one then forget Stihl etc and buy a Makita MM4 one .
https://www.makitauk.com/product/en4950h.html These are 4 stroke so no need for mixing oil issues, they run on just over tickover and use a heck of a lot less fuel than the Stihl. How do I know? Well working with them all for past 12yrs+ and I have my own MM4, but my neighbour against my advice purchased a Stihl and spends more time refilling the fuel tank whilst mine is still running and he's also more tired from the effort to keep th Stihl's 2 stroke engine revved at optimum speed. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4236 ![]() ![]() ![]() |
Hawthorn is a nightmare if it gets out of hand. Best to save up and buy one of those spinning flail mine clearance Challenger tanks, or see if the USAF have any of that stuff for clearing jungles left over from Vietnam. It should be used for prison walls. 2007 110 TDCi Station Wagon XS |
Thanks Zed and Bluest, I've been hunting for some Agent Orange but eBay seems out of stock! It's built up quite a woody crown (I think that's the correct term) having been flailed by the farmer from his side for many years so I've done my best with the hedgecutter, if lock-down continues I may well have a go with the chainsaw attachment on the long-reach jobby simply as something to do since I can't get to the normal chainsaw currently
![]() ![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Similar to the Aldi ones then - but fuel pipe is very cheaper to buy by the metre and clutch can be adjusted. All these tools require maintenance, sharpening, parts changing due to wear and tear. If you are only getting them out of a damp shed once a year and they have last years fuel still in the carb and tank, then they soon become "unreliable". |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 525 ![]() |
Titan is fine - cheap and cheerful - bought from Screwfix and so far has survived farm use for 3 years - what’s not to like. Best thing is spares are cheap - even when a large heavy tree branch fell on the saw head and broke beyond repair, a new stem, head, blade and chain all assembled was £40 delivered.
Any other make would have been bonkers money - at the price they are if they last 3-5 years I don’t care - would definitely buy again 2017 Range Rover L405 Vogue SE V8 Diesel #16 Land Rover 110 300 TDI |
Always like to read how question posts get concluded ...... Went for a Stihl HLE71 in the end. Happy with the job its done in getting a neglected hedge back into shape. Many hours work since April and no complaints. Can feel a little heavy come the end of the day, but don't think that can be avoided with a long reach tool. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
