![]() | Home > Maintenance & Modifications > Replacement lights |
There are a couple of options: if you can get them, fit River Runner 70mm LED light units or fit LED bulbs to standard light units. There are a whole range of opinions available about the legality of the latter but take a look at Classic Car LED's for some very nice replacements and have a search on here for some feedback. Darren
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 283 ![]() ![]() |
Cheers Darren!
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 324 ![]() ![]() ![]() |
I have the classic car LED's and they are outstanding.
There is a thread on them on here so the search function should bring it up. |
Just had a peruse of their website and options seem to be endless. Not too clued up on amps and volts so was hoping you could advise on the ones you fitted to your truck. Many thanks!
I got these
https://www.classiccarleds.co.uk/collectio...9030763615 I also got new wipac crystals but I am sure they would work with any headlamp units with the same results. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17669 ![]() ![]() ![]() |
I think the OP was asking about sidelights not headlights.
I fitted these at the front after doing my headlights because my original sidelight looked so yellow and feeble. https://www.classiccarleds.co.uk/products/...et-fitting |
I fitted the same to mine, for the same reason
![]() ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
I put LED bulbs in standard light units when I had mine, got them from Advanced Factors (site sponsor?), worked a treat!
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello stephan123
I wanted to do the same, up the 'light quality' but keep a standard look, so I bought X4 of these (X2 as Spares) all 3 years ago and the original 2 are still OK. http://www.ebay.co.uk/itm/Land-Rover-Defen...rmvSB=true This was a bit of a trial for me, but I really didn't like the yellowed / warm look of the originals alongside of a decent main headlight bulb, I know there are compliant issues for some but even raising this with my MOT Station all was OK. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 459 ![]() ![]() |
Hi Blackwolf/LRA, Maybe a silly question, but for a 2011 2.4 Puma are these simply just a straight swap with no adjustments needed to the wiring etc? Is it the 'Negative Earth' option we need for the sidelights. I am running Wipac for the main headlights. If so, that's excellent! ![]() |
Yes, just fit them in place of the old bulbs in exactly the same way as a normal bulb. Negative earth is what you need.
Hi Blackwolf,
Thank you very much, I find all these light options very confusing! ![]() Cheers |
I know what you mean, far too many choices now! In the old days it was so simple....
Thanks Skip! Do they also come in amber? I woud rather keep stick with clear lenses for the front indicators. Many thanks |
