Home > Puma (Tdci) > Puma wiring |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Not original. What's no longer working? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
30th Mar 2020 3:37pm |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 |
Not tried yet Martin but that will be my next step.
It comes from the loom so I'm a bit puzzled. I don't think there is anything non-original on the vehicle unless its something to do with the tow bar. I was just going to find another earth in the battery box to use but doesn't seem much of an option at first glance. Thanks for your wisdom! Click image to enlarge Richard Defender 90 SVX |
30th Mar 2020 4:11pm |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 |
That yellow relay is an addition from the non bog standard options (even an XS) so its likely being used for spotlights or something heated perhaps? The white wire shown there is the relay coil earth so it'll be prohibiting it from operating. If it was tow bar it would be related to 13 pin electrics and not 7 pin as there is no call for a single relay on 7 pin.
If you have an SVX with the two lights in the cubby box, it may well be those that the wiring is for, as I haven't seen anything on the normal wiring diagrams to indicate the option on my 110 or any of the others I've worked on. North Cumbria Search and Rescue - Team Leader |
30th Mar 2020 4:16pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2531 |
As per Martin's post, I'd be tempted to switch everything on and make sure it's all working. If everything is working I'd be tempted to tape up the eyelet and leave it. Defender 90XS SW
30th Mar 2020 5:31pm |
Aaaah of course it's the 13 pin/12S towing electrics ground.
It "should" go to a stud on the inner side of the main chassis rail - see step 32 below Instructions: https://www.defender2.net/gallery/albums/u...20TDCi.pdf The ground terminal clamp isn't designed to have extra terminals attached, unlike the positive which has threaded holes. You will have an extra positive wire going off to that yellow relay as well. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
30th Mar 2020 5:33pm |
The plot thickens!
No sign of old spotlights & no lights in the cubby box The seats are heated as is the screen on my SVX; will need to do some more investigation but if it is the relay coil earth then I'll have to find an alternative earthing point so it will start. Richard Defender 90 SVX |
30th Mar 2020 5:35pm |
See above ^^ 1988 90 Td5 NAS soft top
2015 D90 XS SW |
30th Mar 2020 5:43pm |
Thank you to all - nice to have a little bit of detective work during such restrictive times!
I'll use the chassis rail ground as suggested. The original reason for delving into the battery box was to fix a remote terminal for my CTEK so I'll have to find another suitable earth for that. - will keep me busy tomorrow Richard Defender 90 SVX |
30th Mar 2020 6:24pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1082 |
It's a T-shaped bolt head from underneath, right? I replaced the bolt with a longer one and filed the head to shape. |
30th Mar 2020 8:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
I replaced my battery terminal clamps with effective ones!
30th Mar 2020 8:46pm |
Sounds like a plan Richard Defender 90 SVX |
31st Mar 2020 6:46am |
I did the same thing - original bolt on left and new adapted one on right:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Mar 2020 7:01am |
As your Defender is fitted with a tow bar have you thought of connecting your CTEK through the towing socket. Martin has adaptors for both 7 and 13 pin Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
31st Mar 2020 7:23am |
Ah - another plan. I love this website!
Will need to sort the earth first though Richard Defender 90 SVX |
31st Mar 2020 8:31am |
