Home > Technical > Will a td5 defender run with an msb discovery ecu?
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Since ive recently had my ecu partially fail on me and unable to read the signal from the cps sensor correctly its made me slightly concerned about solo overlanding in the alps with the car. Thankfully mine died on the driveway.
I recently fitted a nnn discovery ecu to replace the damaged one and even with the discovery fuel map the car runs fine. Ive not yet copied the map from the old ecu yet as my sd card hasnt arrived.
I was wondering if i pick up a cheap £50-70 MSB discovery ecu to have as a spare on these trips will it run well enough to get me out of trouble in the event of failiure?
Post #821979 29th Mar 2020 9:39am
Mdm
there are a few things that are different such as the temp sender
plenty of folk can rewrite them to defender spec
as these ecu get older more are failing without warning ive had 2 fail last yr on a 2000 td5 and a 2004 td5. neither good be reapired. im running a nnn disco one on my td5 that was reworked a mapper in stockport
Post #821995 29th Mar 2020 10:27am
benniferj
Yes, you could do well by carrying a spare ECU.
You'd do even better to test it before putting it in the spares box and coding your injectors to it etc. Insta: @thebenjordan4x4
Post #822043 29th Mar 2020 12:57pm
LandymanStefan
Thats good, i'll keep an eye out for a cheap one and test it if i do get one.
I think i just need to make sure its from a manual disco right?
Post #822047 29th Mar 2020 1:14pm
It will run yes, but in standard disco format, the temp guage works back to front, and the throttle response is VERY sensitive... horribly so, but at least it'll get you home.
Post #823000 2nd Apr 2020 6:31pm
MadTom
For emergency use, any TD5 ecu will work. Just need IMO pairing made. If you set injector codes, it will be better. With IMO paired, you just plce the ecu in car, no need fo diagnostics.
Also need correct gas pedal set, in case of 3 ways set in ecu and 2 ways placed in car, it will only idle. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #823051 3rd Apr 2020 6:34am
LandymanStefan
Great thanks for the replies, i’ll keep an eye out for a cheap one. Of course only for energency use. When I got my replacement for my faulty one it was from a disco and I did drive it with the disco map on for a little while and it did kangaroo at low revs but I have since put the def fuel map onto it now.
I just want a cheap spare one to have in the car for if the worst does happen when I’m up a mountain somewhere but hopefully i’ll never need it.
Post #823095 3rd Apr 2020 9:30am
