![]() | Home > Puma (Tdci) > Main internal lighting feed |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
MSE
Let me check in the workshop manual and the electric library and I will come back (tomorrow, its quite late here!) Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Here again
I hope the information is that are you looking for ![]() Click image to enlarge Item Part Number Description 1 RH (right-hand) rear door switch (if fitted) 2 Front interior lamp 3 Rear interior lamp (Not 90 model) 4 Tail door switch (Not 90 model) 5 LH (left-hand) rear door switch (if fitted) 6 Map reading lamp (SVX (60th anniversary) model only) 7 Drivers door switch 8 Anti-theft system module 9 CJB (central junction box) 10 Passenger door switch 11 Map reading lamps switch (SVX (60 anniversary) model only) 12 Map reading lamp (SVX (60th anniversary) model only) The CJB is located underside the steering column. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
That looks very interesting !
What are the Map Reading Lights SVX only ? Mike !.................Are you doing what i think you are doing ? DEFENDER XS CSW 08 TONGA GREEN |
Chalky maps lights in front panel of cubby box on SVX. 2.4 90 XS
Cheers grockle !
I think i may well have to invest in some of those and get them wired in. More gadgets to play with i suppose ? I dont suppose there are any SVX owners on here are there ? if so any chance of a picture to illustrate position etc ? DEFENDER XS CSW 08 TONGA GREEN |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5086 ![]() ![]() ![]() |
I dont know ![]() ![]() The lights in the cubby box, switched by a "name escapes me" classic type switch is because the soft top has no interior light...these replace it. Cant say they appeal up close. Sorry i probably wasnt clear im looking for the interior light (switches and instruments) header...maybe number K109 on the 300/td5 it was in the centre of the dash behind the facia. On this i cant find it...if i can want to take a direct feed and not piggy back on one of the other switches. Mike |
thanks Ed, that illustrates that nicely,
Mike i kinda get the idea now and understand the whys and where fores of the lighting on the cubby box ! i,m kinda thinking that could be a bad idea as they will no doubt break and be a general pain in the arse positioned there. DEFENDER XS CSW 08 TONGA GREEN |
Yes - in short ![]() |
