![]() | Home > Puma (Tdci) > Fault codes |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Looks like it could be related to the EGR? Does your BAS remap have the EGR-shut feature? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
yes it does
Hmmm... soon after I started using my BAS remap with EGR-shut I also got a bunch of fault codes and when I put the original map on, the EGR self-cleaning sounded like a wounded cat. The dealer found a problem with one of the EGR harnesses and replaced that. Could be the same thing? See my previous post: http://www.defender2.net/forum/topic6900.html?highlight= -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
many thanks
I forget to mention that prior to this dealer visit I had run the EGR-shut standard remap for a 6000km trip.
So maybe keeping the EGR shut for long periods of time may lead to something sticking in there and then throwing up fault codes? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
