Home > Technical > EGR plate - gasket
donmacn
EGR plate - gasket
Hi folks,
300Tdi - Is there a gasket to go between the exhaust manifold and the EGR blanking plate?
I've searched and found WAL500010L as the recent part number, but it looks like a thick, chunky thing. Almost as thick as the plate itself.
My car never had an EGR, and between the plate and manifold (probably undisturbed since it left the factory) is what looks like a thin layer of something - either gasket, or some sort of old sealant.
I have a plate to fit an EGT probe, but no gasket. Either it didn't come with one, or I've lost it Sad . I don't want to disturb anything now until I know I have all the bits I need.
I guess I could use exhaust paste, but I wouldn't want bits to dry off, then fall into the turbo.
Any advice, or am I over-thinking this as usual?
Ta. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #818086 4th Mar 2020 8:23am
dorsetsmith
BUT you find that ERR4852 has been superseded by WAL500010L
Post #818097 4th Mar 2020 9:30am
donmacn
hi,
Thanks for that.
You're absolutely right - no-one lists the ERR4852 part - just the superceded one.
Are you familiar with ERR4852? Is it a 'thinner' type?
I don't suppose there's anything wrong in principle with using the new one, but I think I'd need longer bolts. Donald
in the past..
Post #818098 4th Mar 2020 9:40am
Oldowner
Almost certain it used to be a orange paper gasket on the 94 models
Post #818123 4th Mar 2020 12:52pm
donmacn
Presumably, because of the heat involved, it can't just be a straightforward paper gasket? I have some 'gasket paper' sheets and could easily cut one out, but I guess it would just burn to a crisp! Donald
in the past..
Post #818132 4th Mar 2020 2:04pm
If it’s anything like the Puma then no gasket required. Just torqued to the correct spec. TheThunder Rolls🇬🇧🇺🇸
Post #818143 4th Mar 2020 4:00pm
