Home > Wheels & Tyres > 315/70/16 MTs Any issues?
bankz5152
So i'm considering new rubber at the end of the year when I get back from Spain and seeing as I likely won't be using my 110 as a daily anymore I was considering moving up one size (current 285/75/160)
Thinking either KM3s, Cooper STT Pros, Maxxis Bighorns in 315/70/16 on Bowler alloys.
Ive got pegged Ashcroft ATBs front & rear & Bailey Morris HD rear prop, Syncro Ultrabuild TX box (ATB, HD bearings etc).
Standard shafts & CVs but may get Ashcroft CVs with standard shafts, unsure yet.
Most things I do is sand driving in France, bit of laning, Salisbury 2 - 3 times year, drive to Spain through Pyrenees each year and a few muddy pay and plays.
The 110 is tuned, big turbo, IC, big map etc...
Am I likely to run into a lot of issues running 35s? or being a bit paranoid. Instagram @defender_ventures
Empire Tuning - Agent
Post #817713 1st Mar 2020 1:52pm
jst
I have always updated shafts and cvs for off roading with 35s. Open diffs included. A 35 finding grip is a big turning moment.
Guess it depends if you want reliability when off tarmac.
Vehicle is lifted to avoid fouling on bump lock I take it? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #817818 1st Mar 2020 9:36pm
bankz5152
Yeah do need it relaible on tarmac as I would be doing some long journeys fairly often. That much of an issue on Tarmac?
Best sticking with a more aggressive 33? Instagram @defender_ventures
Post #817828 1st Mar 2020 10:17pm
topless_matt
Run 35 creep crawlers on my off-roader which also has standard shafts and cvs. Only time I’ve broken one is when “playing” on rocks and using left foot braking.
It is an auto which helps a lot with the forces.
For road use you will be fine, it is the snatch loading that will cause things to break. Hold my beer and watch this!
Post #817844 2nd Mar 2020 6:22am
jst
35s on the torque multiplier of a tdci gbox 1st gear is not something i would be doing if i wanted reliability. thats before engine upgrades and adding ATBs etc. on or off road. i assume more off road from tyre patterns suggested. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #817873 2nd Mar 2020 10:20am
camelman
Been running 35s (bfg ko2)for nearly 3 years now on 2015 puma. Mix on and off road, no issues to date with standard diffs and +2inch suspension
Post #817876 2nd Mar 2020 11:00am
